Exporting Block Models
The export formats available for block models depend on the type of block model:
| Regular block models | Octree sub-blocked models | Fully sub-blocked models | Variable Z sub-blocked models | |
| CSV + text header | √ | √ | √ | √ |
| CSV with embedded header | √ | √ | √ | √ |
| CSV as points | √ | √ | √ | √ |
| Datamine block model | √ | √ | √ | √ |
| Surpac block model | √ | √ | - | - |
| Geosoft voxel | √ | - | - | - |
This topic describes the process for exporting in each of these formats. It is divided into
- Exporting Block Models in CSV Format
- Exporting Block Models in Datamine Format
- Exporting Block Models in Surpac Format
- Exporting Block Models in Geosoft Voxel Format
To export a block model, right-click on it in the project tree and select Export. You will be prompted to select the file format.
If you wish to export the model in one of the CSV formats, select CSV Block Model Files (*.csv). You will be able to choose between the three CSV formats in the next step.
Once you have worked through these steps, a summary of the selected options will be displayed. If you need to make any changes, you can work back through the steps. Once you’re satisfied with the settings chosen, click Export to save the file.
This export format is available for all block model types.
You will then be prompted to work through the custom settings available for the CSV format. If you have exported the block model in CSV format previously, your previous settings will have been saved and so you can quickly click through the windows.
The options that can be set for block models exported in CSV format are:
Choose which objects will be included in the exported file. The Available items list includes all evaluations made onto the model.
You can use a Query filter to filter rows out of the data exported.
The second option in this window is useful when all block results are consistently the same non-Normal status. Select from Error, Without value, Blank or Outside; all rows that consistently show the selected statuses will not be included in the exported file.
Once you have selected the Datamine option and entered a name and location for the file, click Save. You will then be prompted to work through the custom settings available for the Datamine format. If you have exported the block model in Datamine format previously, your previous settings will have been saved and so you can quickly click through the windows.
The options that can be set for block models exported in Datamine format are:
When exporting block models in Datamine format, non-Normal category numeric status codes can be represented in the exported file using custom text sequences. Numeric status codes must be a number or blank. Boolean values are exported using values 0 for false and 1 for true; specify if non-Normal values should be represented by 0 or by the numeric status codes.
When exporting a block model in Datamine format, column names for the evaluated objects have a maximum length of 8 characters. Leapfrog Energy will recommend truncated column names, but if you wish to use different abbreviations, click on the item’s New Name to edit it.
This export format is available for regular block models and octree sub-blocked models.
Choose which format you wish to use, then click Next.
You will then be prompted to work through the custom settings available for the Surpac format. If you have exported the block model in Surpac format previously, your previous settings will have been saved and so you can quickly click through the windows.
The options that can be set for block models exported in Surpac format are:
- The Double option provides precision of 15 to 17 significant decimal places.
- The Single option provides precision of 6 to 9 significant decimal places.
If you are exporting the model in Surpac version 5.0, you can change the Display precision used for the Double and Single options.
When exporting block models in Surpac format, non-Normal category numeric status codes can be represented in the exported file using custom text sequences. Numeric status codes must be a number. Status codes cannot be used for Boolean values; non-Normal values are set to false.
This export format is only available for regular block models.
Once you have selected the Geosoft Voxel option and entered a name and location for the file, click Save. You will then be prompted to choose which properties will be included in the exported file. The Available items list includes all evaluations made onto the model.
