Lighting Settings
The settings in the Lighting tab of the Settings window change how visual effects are displayed in the scene window. Changes you make to these settings are previewed in the scene so you can easily experiment to see what overlays you prefer. To confirm changes, click the Close button. Click Revert to return to the settings in place when the Settings window was first opened.
You may be able to use these settings to emphasise significance in the data displayed in the scene.
- The Ambient level setting determines the overall brightness of the scene.
- The Specular brightness and Specular shininess settings determine how light appears to fall on the surfaces in the scene. The Specular brightness setting has a stronger effect when Specular shininess is soft.
You can have up to four light sources defined for a project. By default, two light sources are defined.
Changes made to these settings are automatically applied to the scene.
- Click Revert to return to the settings in place when the Settings window was first opened.
- Click Reset to revert to the lighting sources and settings defined when Leapfrog Energy was first installed.
