Usage Policy Settings
The Usage Policy tab in the Settings window contains settings related to how long Leapfrog Energy will remain idle and reference codes:
Idle Time-out
When the Idle time-out setting is enabled, Leapfrog Energy will prompt you after a period of inactivity. Follow the instructions in the message displayed.
Reference Codes
Leapfrog Energy can use reference codes to track work on specific projects. The number of days associated with each reference code is included in your organisation’s monthly usage report. In the Settings > Usage Policy window, you can define reference codes on a per-project or per-computer basis. Click the Add New Code button to add a code for either the computer or the currently open project.
The other two settings can be used to ensure that you are regularly prompted to update the reference code.
- Prompt at project start up ensures that a prompt is displayed for selecting a reference code whenever a project is opened or a new project is created.
- Always required ensures that Leapfrog Energy is not used without a reference code being selected; <No Code> is not an option.
The Revert button at the bottom of the Settings window reverts settings to those in place when the Settings window was first opened. This includes changes made in other tabs, not just the tab you are currently in.
To apply any changes made, click Close.
