Block Models
You can create the following types of block models in Leapfrog Energy:
- Regular block models. A regular block model has blocks that are all the same size and are never divided.
- Octree sub-blocked models. An octree sub-blocked model has blocks that are repeatedly divided into eight sub-blocks where selected triggering surfaces intersect the blocks. Instead of dividing a block entirely into small sub-blocks when sub-blocking is triggered, the block is first divided in half in a particular direction, and then only the partitioned blocks that still trigger a further division are divided into smaller units. This creates a series of sub-blocks of different sizes, and because many are larger than the smallest sub-block and the smallest sub-blocks only exist where a contact requires it, processing can be more efficient.
- Fully sub-blocked models. With fully sub-blocked models, blocks are fully sub-divided when they contain a triggering boundary. This can create many sub-blocks and so processing a fully sub-blocked model can be slower than processing an octree-sub-blocked model. In contrast to octree sub-blocked models, however, fully sub-blocked models support block subdivisions using numbers other than power-of-two numbers. Fully sub-blocked models do not support variable height sub-blocks.
- Variable Z sub-blocked models. Variable Z sub-blocked models are fully sub-blocked in X and Y, but in Z the size of the sub-blocks varies to exactly follow triggering boundaries.
You can also:
- Regularise octree sub-blocked models, fully sub-blocked models and variable-z sub-blocked models into a block model that is not sub-blocked. Regular block models can be regularised into a block model with larger block dimensions and fewer blocks. See the Regularising Block Models topic.
- Export block models. See the Exporting Block Models topic.
- Import block models in different formats. See the Importing Block Models topic.
The rest of this topic describes:
Creating New Block Models
To create a new block model, right-click on the Block Models folder and select New Block Model. In the window that appears, select the type of block model you wish to create:
For more information on each block model type, see the following separate topics:
- Creating a Regular Block Model
- Creating a New Octree Sub-blocked Model
- Creating a Fully Sub-blocked Model
- Creating a Variable Z Sub-Blocked Model
Block Model Volume Filters
Mesh volumes can be assigned to block models as volume filters. Right-click on a block model in the project tree and select New Volume Filter. Select the volume from the list of available objects.
Volume filters will appear as selectable options in the shape list properties panel’s Query filter, where the volume filter can be selected to show only the parts of the block model within the selected volume.
Displaying a Block Model
The Fill slicer option provides the choice between an outlined shape for the intersection of each block with the slicer, or a filled shape.
The Show text option provides the choice between seeing a value on screen for each block intersecting the slicer, or not. The default value is the value for the column selected to colour the block model.
When a block model is displayed in the scene, there is a Query Filter option that includes filters created in Calculations and Filters.
The Query filters list will also contain volume filters. To set a volume filter on a block model, see Block Model Volume Filters.
- If a category column is chosen, a Select Categories button can be used to select the discrete categories to show.
- If a value column is chosen, a value range filter is shown.
- If a date column is chosen, a date range filter is shown.
For more information on how to use the Display filter, see the Using the Display Filter section in Visualising Data.
- Subset shows the union of the selected X, Y and Z ranges.
- Sliced shows the intersection of the selected X, Y and Z ranges.
The X, Y and Z ranges each use a range slider.
The Table of Statistics option is described in more detail below. See the Statistics topic for more information on the other options.
Right-clicking on a block model evaluation or a numeric calculation and selecting Statistics opens a univariate graph for the selection. See Univariate Graphs in the Statistics topic for more information.
Table of Statistics
The Query filter option uses a related filter to constrain the dataset to a selected subset.
Group by category and Group by numeric column provide options for the table organisation. You can also change what columns are displayed in the table by clicking the Edit columns button (
). This opens a window in which you can select the columns that are displayed in the table:
Click rows to select them, and select multiple rows by holding down the Shift or Ctrl key while clicking rows. You can then copy rows by clicking the Copy button (
), which allows you to copy the selected row(s) or all rows in the table.
The arrow buttons quickly expand (
) or collapse (
) rows.
