Importing Data from Seequent Evo
See the Leapfrog Energy/Seequent Evo Data Flow topic for an overview of importing, publishing and reloading Evo data.
This topic discusses the process of importing data from Seequent Evo. It is divided into:
- Starting the Import Process
- The Import from Seequent Evo Window
- Importing Drilling Data from the File Service
- Importing Block Models
To start importing data from Seequent Evo, right-click on a folder in the project tree and choose the Seequent Evo option (A) from the Import menu:
Importing data into a Leapfrog Energy project is similar to importing data from local files, except you must first specify the workspace that contains the data you wish to import.
- If you are unsure as to what workspace contains the data you wish to import, click the Go to Seequent Evo button (B) to open Seequent Evo in your web browser.
- If a workspace you expect to see is not listed, click on the Evo menu next to the user ID menu and click the Refresh button (
For drilling data, you can choose whether to import data from Evo’s Geoscience Object service or from the File service:
Importing drilling data from the File service is discussed in further detail in Importing Drilling Data from the File Service later in this topic.
Once you have chosen the workspace you want to import data from, all data in the workspace that matches the data type you are importing will be displayed. Tick the box for any object you wish to import. There are Select All and Select None buttons to assist with this selection process.
With the column button (
), you can choose which columns appear in the table, which can assist in selecting which data to import when the workspace contains a lot of data.
You can also filter the list to limit how many objects are displayed. You can choose which columns are used to filter the list by clicking on Filter on columns. When no columns are selected, the filter is applied to only object names.
Note that filtering out objects in this way does not deselect them, if they were selected before the filter was applied.
Once you have selected the objects you wish to import, click the Import button. In most cases, the objects will be added to the Leapfrog Energy project tree.
Objects in a project that have been imported from Evo are indicated in the project tree using an Evo badge, which is the case for the Topography and DEM Balcooma objects here:
Some objects imported from Evo will include an associated colourmap. If this is the case, the colourmap will be automatically applied to the imported object. The colourmap will appear in the Colourings > Shared Colourmaps > Imported folder in the project tree, where it can be applied to other objects in the project.
In addition to importing drilling data from Evo’s Geoscience Object service, you can also import drilling data from Evo’s File service. To do this, right-click on the Well Data folder in the project tree and select Import Wells > Seequent Evo > File.
In the window that appears, click the Collar button:
Choose the file you wish to use from the list of those available and click Import to return to the Import Wells From Seequent Evo window. Repeat the process for files you wish to import until all are listed in the Import Wells From Seequent Evo window. Click Import to start working through the files as described in Importing Data Tables.
A drilling dataset will be added to the project tree in the Well Data folder.
You can import additional drilling data tables to an existing drilling dataset from Seequent Evo, but you can only do so from the Geoscience Objects service. To import additional tables, right-click on a drilling dataset and select Import From Seequent Evo, then select the data type you wish to import.
If you are importing block models from Seequent Evo, an extra step is required in the import process. This is to select the spatial extents and columns you wish to import.
Fore more information on importing block models from Seequent Evo, see Importing a BlockSync Block Model in the BlockSync integration help.
