Filtering Data
You can define filters for data tables that select a subset of data for future processing. Filters can also be used when displaying data in the scene.
Leapfrog Energy has two types of filters:
  • Query filters are available for any type of table in a Leapfrog Energy project, including drilling data, GIS data, points data and structural data. Query filters are based on criteria specified in the query builder. Two different query builders are used in Leapfrog Energy, the standard query builder that is used for most data tables and the points query builder that is used for imported points data tables.
  • Volume filters are available for drilling data. Volume filters are defined from a boundary box or a closed volume.
Here a volume representing a vein system has been used to filter the drilling data to show the data that intersects the volume:
A volume filter in the project tree, built from a mesh and applied to a table through the Query filter list
The rest of this topic describes how to build and use query filters in Leapfrog Energy. It is divided into:
Creating a Query Filter
Two different query builders are used in Leapfrog Energy:
Creating a Volume Filter
Volume filters are available for drilling data. To create a volume filter, right-click on a collar table in the project tree and select New Volume Filter.
The New Volume Filter window, where the filter boundary is set from custom extents or an existing volume
You can define the filter boundary in three ways:
  • Enter the volume coordinates using the X, Y and Z Minimum and Maximum coordinates.
  • Select Enclose Object and choose from the list of objects in the project.
  • Select Existing model boundary or volume, then click on the Select Surface button and choose from the list of volumes in the project.
The Existing model boundary or volume option allows the selection of a closed volume that is not a cuboid.
Using Filters in Objects and Models
When creating or editing objects or models, you can use a query filter to filter the data used. For example, here you can use one of the query filters defined for the drilling data to create a new geological model from the drilling data for a specific drilling campaign:
The Filter data list when creating a geological model, offering the query filters defined on the collar table
Correlation sets that have been defined may also appear in this list of available filters as alternative options for filtering the data, if the data can be filtered using collar IDs.
Here a structural data table is used to create a form interpolant. The query filters on the structural data table can be used to filter the data used in the interpolant:
A query filter being chosen for a structural data input when creating a form interpolant
It is also possible to change the filter used after the object has been created. For example, here we can choose a different filter for an existing geological model:
The Filter data setting of an existing geological model, changed from its properties window
Using a Filter in Displaying Data
To apply a filter to the scene, select the object in the shape list, then select the filter from the Query filter list in the shape properties panel. For drilling data, any defined volume filters can will also be displayed in the Query filters list.
Choosing a query filter for a table in the shape properties panel, listing the filters defined on the collar table
For a drilling data table, this displays only the data selected by the filter. The trace lines remain displayed in the scene. To filter out the trace lines so they are not displayed in the scene, tick the Filter trace lines box:
The Filter trace lines checkbox ticked so that trace lines are hidden along with the filtered-out data
