Grouping Lithologies
The group lithologies tool lets you define a new unit to which existing units are added. For example, a sandstone deposit might appear in an interval table as poorly-sorted and well-sorted units. The group lithologies tool lets you group both units into a single sandstone unit.
When you group lithologies, the original lithology column is preserved and a new lithology column is added to the interval table. You can then select the original lithology column or the new one when displaying data and creating models.
To start grouping two or more lithologies, right-click on the interval table in the project tree and select New Column > Group Lithologies. The New Lithology Column window will appear:
The New Lithology Column window, with the base column chosen and a name for the new grouped lithology column.
A window will appear displaying all lithologies in the base lithology column:
The grouped category window with every lithology still ungrouped, and the two spellings of Alluvium boxed at the top of the list.
In this example, two spellings of Alluvium have been used and these lithologies should be combined into a single lithology.
The most straightforward way to group lithologies is to select the first of the lithologies, then click New Group. A group will be created for the selected lithology with only that lithology as a member:
A new group created from one lithology, holding that lithology as its only member.
Next, click on a lithology in the Ungrouped Lithologies pane and drag it onto the group:
A lithology being dragged from the Ungrouped Categories list onto an existing group.
Grouping lithologies creates a new lithology column and any lithologies left in the Ungrouped Lithologies pane will be excluded from the new column. For this reason, once you have grouped the required lithologies, move all remaining lithologies to the Groups pane by clicking on each lithology, then on the New Group button. This will make each remaining lithology a new group with a single member:
Every lithology moved into the Groups list, the two spellings sharing one group and each remaining lithology forming a group of its own.
When you are finished, click OK to create the new lithology column. It will appear in the project tree as an additional lithology column in the interval table.
Select the new column from the shape list to display it:
The shape list colouring dropdown open, with the new GroupedLithologies column beside the original lithology column.
Click on the Edit button () to start editing the selected column.
The other way to group lithologies is to let Leapfrog Energy create the lithology groups.
Automatic Lithology Groups
Leapfrog Energy can automatically create lithology groups. To do this, create a new lithology column, as described above. Click the Auto Group button to reveal more options:
The Group Values By options revealed by Auto Group, offering grouping by the first or last letters of the lithology names or one group per value.
The First letter(s) and Last letter(s) options let you create groups according the names of the existing lithologies. Click Group to create the new groups.
Here, the first two letters have been used to created a new set of lithologies:
Grouping by the first two letters, which puts both spellings of Alluvium into a single Al group and each other lithology into its own two-letter group.
The two alluvium lithologies have been added to a single group.
The One group per value option creates a group for each original lithology. You can then drag and drop lithologies into different groups, move lithologies you do not wish to group back into the Ungrouped Lithologies pane and use the Delete Groups options to remove any empty groups.
