Intrusions
Intrusion contact surfaces are useful for modelling units that are rounder in shape, with an interior lithology that represents the intrusion lithology. The intrusion removes existing lithologies and replaces them with the intrusive lithology on the younger side of the contact surface. Often, the older side of an intrusion contact surface is labelled Unknown as typically intrusions displace multiple older lithologies.
This topic describes creating and editing intrusions. It is divided into:
For a general introduction to how intrusions interact with other contact surfaces, see Intrusion Contact Surfaces in the Building Surfaces Using the Surface Chronology topic.
Creating Intrusions
Lithology data is often the most reliable data source to use when building geological surfaces, and it is best to derive contact surfaces from lithology data when it is available. If no lithology data is available, you can create intrusions from other data in the project.
One thing to keep in mind for all intrusion contact surfaces is that an intrusion removes all the existing material on the younger side of the contact surface. Therefore:
  • An intrusion should always have the younger side of its surface labelled with the intruded material. This is called the “interior lithology”.
  • The older side will typically be labelled “Unknown” as an intrusion will usually displace multiple older lithologies. This is called the “exterior lithology”.
Intrusions from Lithology Contacts
Lithology data is often the most reliable data source to use when building geological surfaces, and it is best to derive contact surfaces from lithology data when it is available. There are two ways to create intrusions from lithology data:
  • Using the base lithology column assigned when the model was created.
  • Using other lithology information available in the project. This is useful when you have created an additional lithology column as part of correcting and working with the drilling data or if you have multiple drilling datasets in the project. For example, if when building a geological model it becomes apparent that changes need to be made to the drilling data, you can import additional data or create a new column using the split lithology, group lithology or interval selection tools.
To create a new intrusion from lithology contacts, right-click on the Surface Chronology object and select either New Intrusion > From Base Lithology or New Intrusion > From Other Contacts. The only difference in the two methods is that when creating an intrusion from other contacts, you must first select the lithology column from those available in the project and specify the First lithology and the Second lithology.
Select the intrusive lithology as the interior lithology. Other lithologies will be displayed in the Exterior lithologies list. Drag any younger lithologies to the Ignore list.
The Lithology tab of the New Intrusion dialog, with I1 chosen as the interior lithology, the remaining lithologies listed under Exterior lithologies, an empty Ignore list, and unspecified intervals set to Ignore.
Unspecified intervals are intervals that have no data. By default, unspecified intervals are ignored when creating an intrusion, but you can also treat them as the interior lithology or as exterior lithologies.
Sometimes intrusive boundaries are poorly defined, with fragments of country rock intermixed with the intrusive body. This can result in very small segments near the edges of the intrusion. Modelling the fine detail is not always necessary, and so compositing can be used to smooth these boundaries. Compositing parameters are set in the Compositing tab:
The Compositing tab of the New Intrusion dialog, with Simplify geology by converting short segments ticked and Set from surface resolution supplying the interior and exterior segment lengths.
The settings in this tab, other than the Set from surface resolution option, are the same as described in Category Composites. That topic uses drillhole data and visualises the effect of compositing in generating category composites in different situations and with different compositing options. Refer to that topic to get insight into what actions are being taken when compositing data to produce a lithology contact surface.
When choosing to Simplify geology by filtering short segments, the Set from surface resolution option will scale what detail is filtered out in compositing according to the selected surface resolution for the geological model lithologies.
Click OK to create the intrusion, which will be added to the project tree as part of the Surface Chronology object.
Intrusions from Other Data
If suitable lithology data is not available, intrusions can be created from other data in the project, such as GIS data, structural data, points, polylines and surfaces. The steps for creating intrusions from other data are similar, regardless of the data used to create the surface:
  • Right-click on the Surface Chronology and select one of the data types from the New Intrusion menu.
  • Select the data object that will be used to define the surface. This must already be in the project, unless you are using a polyline, in which case you are given the option to create a new polyline.
  • Select the First lithology and Second lithology. These are the lithologies that will be assigned to each side of the contact surface. The lithologies you can choose from are those defined for the geological model in the Lithologies object (see Geological Model Lithologies).
  • Set whether the First lithology is older or younger than the Second lithology. Leapfrog Energy will, by default, put the younger side of a contact surface up, but this can be changed later.
Here, a points data object is being used to create an intrusion:
Creating an intrusion from a points object: clicking Select in the New Intrusional Contact dialog opens the Select points dialog, where the intrusion points object I1 is chosen.
For polylines, you first set the lithologies and the younging order, then click OK to move on to the next step:
Creating an intrusion from a polyline: after setting the lithologies and younging order and clicking OK, the New Polyline dialog appears with New Drawing selected.
You can draw the polyline in the scene directly by selecting the New Drawing option. You can also use any polyline in the project by selecting the Existing Polyline option. You can then select the required polyline from the list.
The new intrusion will appear in the project tree under the Surface Chronology. Add the contact surface to the scene to view it and check that it is oriented correctly.
Expand the surface in the project tree to see how it was made.
If creating a surface from a new polyline, the polyline will not be able to be used elsewhere in the project unless it has been shared. To share the polyline, expand the contact surface in the project tree, right-click on the polyline and select Share. The polyline will then be available elsewhere in the project.
Intrusions in the Project Tree
The name Leapfrog Energy automatically assigns to an intrusion is the name of the intrusive lithology. In the project tee, expand the intrusion to see how it was made:
The intrusion I1 expanded in the project tree under the Surface Chronology of the RockType geological model, showing the intrusion points object and the lithology column it was made from.
Double-click on the intrusion surface () to edit it. Double-click on the points object () to edit the intrusion lithology, change compositing parameters and change point generation options.
As further refinements are made to the surface, that information will also be added to the project tree. See Refining Intrusions below for more information.
You can copy intrusions, which is useful in experimenting with the effects of different settings and in ensuring the consistency of settings across surfaces. To do this, right-click on the surface in the project tree and select Copy. Enter a name for the copy, then click OK.
Contact surfaces can only be copied within a geological model; they cannot be copied to other models.
Copied surfaces are set to inactive in the Surface Chronology, so making a copy of a surface results in no processing changes to a geological model.
Displaying Intrusion Points
When you view the intrusion points in the scene, you can display only the contact points or all the points used in creating the intrusion. To display all points, click on the points object () in the shape list and tick the box for Show volume points. Here, only the contact points are displayed:
An intrusion surface in the scene with Show volume points unticked, so only the contact points are displayed.
When the volume points are displayed, points with negative values are those outside the surface, while points with positive values are those inside. Show text () has been enabled in the shape list so that the values are displayed:
The intrusion displayed with volume points and Show text enabled, so each point's value is labelled: negative values outside the surface and positive values inside.
You can change the way intrusion points are generated by double-clicking on the points object () in the project tree. See Intrusion Point Generation Parameters.
Refining Intrusions
You can refine intrusions in several ways:
  • Add other data. Right-click on the surface to see the options available, which will depend on how the surface was created. See Adding Data to Surfaces for more information.
  • Edit the surface with a polyline. Right-click on the surface in the project tree and select either Edit > With Polyline. See Editing Surfaces With Polylines for more information.
  • Edit the surface using structural data. Right-click on the surface and select Edit > With Structural Data. See Editing Surfaces With Structural Data for more information.
To edit an intrusion’s settings, double-click on it in the project tree. In the Lithologies tab, change the lithologies assigned to each side of the surface, if required.
Surfacing Options for Intrusions
Boundary Filtering
  • Filter the data. The surface is only influenced by the data that falls inside the surface’s boundary.
  • Leave the data unfiltered. The surface is influenced by the data both inside and outside the surface’s boundary.
The boundary of an intrusion can be the geological model boundary or a fault block boundary.
  • Inherit from GM. The setting for the geological model as a whole is used. This is the default setting.
  • Off. Data is not filtered.
  • All data. All data is filtered.
  • Drilling only. Only drilling data and data objects derived from drilling data are filtered.
  • Custom. Only the data objects specified in the Inputs tab are filtered.
Snapping to Data
  • Off. Surfaces do not snap to the data used to create them.
  • All data. Surfaces snap to all data within the Maximum snap distance, which includes drilling data and any data added to the surfaces.
  • Drilling only. Surfaces snap to drilling data and data objects derived from drilling data within the Maximum snap distance but not to other data used to modify the surfaces.
  • Custom. Surfaces snap to the data objects indicated in the Inputs tab for each surface.
Surface Resolution
See Surface Resolution for a Geological Model in the Creating and Editing a Geological Model topic for information about the surface resolution settings in the Surfacing tab.
Clicking Additional options adds Value Clipping and Interpolant tabs to the window and also allows the use of a structural trend in the Trend tab:
The Surfacing tab for an intrusion, with an arrow pointing to the Additional options button.
These are described in Applying a Trend to an Intrusion, Clipping Values for Intrusions and Interpolation Settings below.
There are two ways to change the trend for an intrusion:
  • Right-click on the surface in the project tree and select Adjust Surface.
  • Double-click on the surface in the project tree and then click on the Trend tab.
You can also use a structural trend for an intrusion. To do this, click the Additional options button in the Surfacing tab, then click on the Trend tab.
The Trend tab for an intrusion with Structural Trend selected, highlighting the trend dropdown, Outside value and the Clustering Settings beneath it.
Click on Structural Trend, then select the required trend from the list. For more detailed information, see the Building a Structural Trend and Clustering Settings and Visualisation topics.
You can change settings for intrusions by double-clicking on the contact surface in the project tree. The Value Clipping tab is only available for intrusion contact surfaces.
In the Value Clipping tab, you can manipulate the data distribution by clipping the data:
The Value Clipping tab for an intrusion, showing a histogram of the distance values with clipping turned off and the Lower bound and Upper bound fields empty.
Clipping caps values that are outside the range set by the Lower bound and Upper bound values. For example, if you change the Upper bound from 16.00 to 10.00, distance values above 10.00 will be regarded as 10.00.
The Automatic clipping setting has different effects based on whether a global trend or structural trend is set in the Trend tab:
  • When a global trend is applied, Leapfrog Energy automatically clips the values. That is, the Automatic clipping setting is Do clipping and Leapfrog Energy sets the Lower bound and Upper bound from the data. To disable clipping, untick Automatic clipping, then untick Do clipping. To change the Lower bound and Upper bound, untick Automatic clipping, then change the values.
  • When a structural trend is applied, Leapfrog Energy automatically does not clip the values. To clip values, untick Automatic clipping, then tick Do clipping. Again, Leapfrog Energy sets the Lower bound and Upper bound values from the data and you can change them, if required.
You can change settings for an intrusion by double-clicking on the intrusion in the project tree and clicking on the Interpolant tab. For more information on the settings in this tab, see the Interpolant Functions topic.
