Structural Surfaces
A structural surface uses contact data and non-contact structural data to create a surface. A structural surface can interact with other volumes in the model as a deposit, an erosion or an intrusion contact surface. The shape of the structural surface is suggested by the non-contact structural data used.
When creating a structural surface, there are two options for declustering the non-contact structural data:
  • The input data is automatically declustered as part of creating the structural surface. There are no additional controls that determine how the data is declustered.
  • Use a declustered structural dataset as the non-contact input to the surface. This approach is recommended over the first approach as you can change how the data is declustered.
The rest of this topic describes how to create and work with a structural surface. It is divided into:
Creating a Structural Surface
To create a new structural surface, right-click on the Surface Chronology and select New Structural Surface. The New Structural Surface window will appear:
The New Structural Surface dialog, with empty tables for non-contact structural data and other input data, lithology and younging order dropdowns, and Contact Type set to Deposit.
Use the Add buttons to add non-contact structural data and on-surface contacts, then set the First lithology and Second lithology. Other settings are:
  • Query Filter. Select from the query filters defined for the selected structural data object.
  • Use Polarity. Untick the box to use tangents only.
  • Contact Type. Structural surfaces can be deposit, erosion or intrusion contacts. The same algorithm is used for each setting; the only difference is in how the surface interacts with other surfaces.
The Structural Surface in the Project Tree
The name Leapfrog Energy automatically assigns to a structural surface is the lithologies assigned to each side of the surface. In the project tree, expand the surface to see how it was made:
A structural surface expanded in the project tree, showing the contact data it was made from and, under a Non-contact structures heading, the two structural data objects used.
As further refinements are made to the surface, that information will also be added to the project tree. See Refining a Structural Surface below for more information.
To add more non-contact structural data to the surface, right-click on it in the project tree and select Add > Structural Data. In the window that appears, tick the box for Non-contact Structural Data:
Adding non-contact structural data to a structural surface: right-click the surface, select Add then Structural Data, and tick Non-contact Structural Data in the window that appears.
You can copy structural surfaces, which is useful in experimenting with the effects of different settings and in ensuring the consistency of settings across surfaces. To do this, right-click on the surface in the project tree and select Copy. Enter a name for the copy, then click OK.
Contact surfaces can only be copied within a geological model; they cannot be copied to other models.
Copied surfaces are set to inactive in the Surface Chronology, so making a copy of a surface results in no processing changes to a geological model.
You can refine structural surfaces in several ways:
  • Add other data. Right-click on the surface to see the options available, which will depend on how the surface was created. See Adding Data to Surfaces for more information.
  • Edit the surface with a polyline. Right-click on the surface in the project tree and select either Edit > With Polyline. See Editing Surfaces With Polylines for more information.
  • Edit the surface using structural data. Right-click on the surface and select Edit > With Structural Data. See Editing Surfaces With Structural Data for more information.
The Contact Type setting determines how the structural surface interacts with other lithologies, as described in Building Surfaces Using the Surface Chronology. A structural surface can be a deposit, erosion or intrusion contact surface.
For information on other techniques for refining structural surfaces, see Surfacing Options for a Structural Surface below.
Surfacing options for a structural surface are accessed by double-clicking on the surface in the project tree and clicking on the Surfacing tab. There are additional settings related to boundary filtering and snapping to data in the Inputs tab.
Setting the Surface Resolution
Boundary Filtering
  • Filter the data. The surface is only influenced by the data that falls inside the surface’s boundary.
  • Leave the data unfiltered. The surface is influenced by the data both inside and outside the surface’s boundary.
The boundary of a structural surface can be the geological model boundary or a fault block boundary.
  • Inherit from GM. The setting for the geological model as a whole is used. This is the default setting.
  • Off. Data is not filtered.
  • All data. All data is filtered.
  • Drilling only. Only drilling data and data objects derived from drilling data are filtered.
  • Custom. Only the data objects specified in the Inputs tab are filtered.
Snapping to Input Data
  • Off. Surfaces do not snap to the data used to create them.
  • All data. Surfaces snap to all data within the Maximum snap distance, which includes drilling data and any data added to the surfaces.
  • Drilling only. Surfaces snap to drilling data and data objects derived from drilling data within the Maximum snap distance but not to other data used to modify the surfaces.
  • Custom. Surfaces snap to the data objects indicated in the Inputs tab for each surface.
Non-Contact Structural Inputs Settings
For the non-contact structural inputs, you can:
  • Change the Query Filter setting. Select from the query filters defined for the selected structural data object.
  • Change the Use Polarity setting. Untick the box to use tangents only.
  • Change the Boundary filter setting, if the Boundary filter setting in the Surfacing tab is set to Custom.
Applying a Trend to a Structural Surface
There are two ways to change the trend for a structural surface:
  • Right-click on the surface in the project tree and select Adjust Surface.
  • Double-click on the surface in the project tree and then click on the Trend tab.
Value Clipping
In the Value Clipping tab, you can manipulate the data distribution by clipping the data. Clipping caps values that are outside the range set by the Lower bound and Upper bound values. For example, if you change the Upper bound from 16.00 to 10.00, distance values above 10.00 will be regarded as 10.00.
When Automatic clipping and Do clipping are enabled, Leapfrog Energy sets the Lower bound and Upper bound from the data. To change the Lower bound and Upper bound, untick Automatic clipping, tick Do clipping and then change the values.
