Comparison Histograms
Comparison histograms are used for compositing and declustering statistics, with the options Compositing Comparison and Declustering Comparison respectively. They feature a double histogram, one displaying the distribution of the raw data and one displaying the distribution of the data after processing. This enables comparison of the two distributions of the same element before and after the data transformation. Impacts on the symmetry of distributions will be evident.
A comparison histogram of composited against uncomposited silver values, drawn as mirrored blue and orange distributions with a table comparing their statistics
In the Histogram settings, you can choose between Inverted graphs, as shown in the image above, or Side by side graphs where the data for each histogram bin is shown in the traditional histogram style. Bin width changes the size of the histogram bins used in the plot. Percentage is used to change the Y-axis scale from a length-weighted scale to a percentage scale.
Enabling Display summary statistics on plot will replicate the summary statistics for the dataset as a legend on the plot.
With Display summary statistics on plot ticked, the full comparison of composited and uncomposited statistics is repeated as a legend on the chart
If a more concise legend is preferred with only the key statistics, enable Simplify summary statistics:
With Simplify summary statistics ticked, the legend on the chart is reduced to count, length, mean, standard deviation, minimum and maximum for each distribution
The declustering comparison chart will also have Input Values options where the Declustered values and Statistic weighting options can be selected from the dropdown lists:
The Input Values section of a declustering comparison chart, with Decluster weighting and Statistics weighting dropdowns
Styling Elements in a Comparison Histogram
You can change the size of various elements of the comparison histogram, such as the sizes of different labels. To do this, click the Edit reporting display settings button ():
The Reporting Display Settings window for a comparison histogram, opened from the toolbar button
By default, the comparison histogram will use the global graph settings. For more information, see Graphs Settings.
If you tick the Use local graph settings box, the sliders will adjust the chart features for the chart currently open.
With Use local graph settings ticked, the Title Size slider changes the title size of the open comparison histogram
Exporting a Comparison Histogram
Comparison histograms can be exported as PDF, SVG and PNG files. Click the Export button (), then specify a filename and select the file type you prefer.
Alternatively, you can click the Copy button () then select Copy Graph Image; an image of the chart will be added to the clipboard. You can then paste the image from the clipboard into another application.
