Univariate Graphs
Univariate graphs plot a single data series.
A univariate histogram of zinc with its settings panel, statistics table and the box plot drawn beneath the chart
This type of chart option will also appear in the Statistics options as Interval Length Statistics, Compositing Interval Lengths, Estimation Values Univariate, Decluster Weights Univariate or Decluster Values Univariate, some with an additional Input Values section.
The Input Values section of a Decluster Weights Univariate chart, with a Values dropdown The Input Values section of a Decluster Values Univariate chart, with Statistics weighting and Decluster weighting dropdowns
Where a Values dropdown is available, select from the data input values in the dropdown list.
If there is a Statistics weighting field, choose <None> or an available weighting type from the dropdown list.
If there is a Decluster weighting fields, choose <None> or one of the declustering weight options available in the dropdown list.
There are several different visualisation options. Histogram shows a probability density function for the values, and Cumulative Histogram shows a cumulative distribution function for the values as a line graph.
The same data shown as a histogram and as a cumulative histogram
There are three options that show the charts with a log scale in the X-axis:
  • Select Histogram and enable Histogram of the log to see the value distribution with a log scale X-axis.
  • Select Cumulative histogram and enable Histogram of the log to see a cumulative distribution function for the values with a log scale X-axis.
  • Log probability is a log-log weighted cumulative probability distribution line chart.
The same data plotted with a log scale X axis as a histogram of the log, a cumulative histogram of the log and a log probability chart
Percentage is used to change the Y-axis scale from a length-weighted scale to a percentage scale.
Bin width changes the size of the histogram bins used in the plot.
Some univariate graphs may include a Filtering section. Here is where a Query filter defined for the dataset can be selected.
There may also be a Categories list where category columns can be added by clicking the Add button (), then selecting a category data column from the left dropdown list, and choosing specific category values from the right dropdown list.
A category column added to the Categories list, with its dropdown open to tick individual categories and Include Null Values
There is also an Include Null Values option, which allows you to include values in a chart even though there are missing values in a certain category data column, instead of filtering the data row out.
Enabling Display summary statistics on plot will replicate the summary statistics for the dataset as a legend on the plot.
With Display summary statistics on plot ticked, the full set of statistics is repeated as a legend on the chart
If a more concise legend is preferred with only the key statistics, enable Simplify summary statistics:
With Simplify summary statistics ticked, the legend on the chart is reduced to count, length, mean, standard deviation, minimum and maximum
Saving a Univariate Chart
Some univariate charts have a Save icon () that adds the chart to the Saved Statistics folder.
This will create a copy of the univariate chart with a default name. You can then modify the name of the chart so you can more easily find it in the Saved Statistics folder. You can also switch back to the original univariate chart and make further changes, then save additional versions of the chart to the Saved Statistics folder.
Clicking Save creates a copy of the univariate chart with a default name and switches to displaying the saved copy
Once saved to the Saved Statistics folder, subsequent changes to the chart are automatically saved.
Styling Elements in a Univariate Chart
You can change the size of various elements of the univariate chart, such as the sizes of different labels. To do this, click the Edit reporting display settings button ():
The Reporting Display Settings window for a univariate chart, its sliders greyed out because Use local graph settings is unticked
By default, the univariate chart will use the global graph settings. For more information, see Graphs Settings.
If you tick the Use local graph settings box, the sliders will adjust the chart features for the univariate chart currently open.
With Use local graph settings ticked, dragging the Title Size slider enlarges the title of the open univariate chart
Exporting a Univariate Chart
Univariate chart can be exported as PDF, SVG and PNG files. Click the Export button (), then specify a filename and select the file type you prefer.
Alternatively, you can click the Copy button () then select Copy Graph Image; an image of the chart will be added to the clipboard. You can then paste the image from the clipboard into another application.
