Declustering Planar Structural Data
If a planar structural data table contains multiple duplicate or near-duplicate measurements, you can create a declustered structural dataset that will make the table easier to work with. Declustering is intended to work with large, machine-collected datasets rather than smaller sets that might be edited manually.
  • The Spatial search radius determines the size of the declustering space. All points inside the Spatial search radius are compared searching for duplicates.
  • The Angular tolerance measures whether points have the same or similar orientation. The orientation of all points inside the Spatial search radius is measured and the mean taken. If a point’s orientation is less than the Angular tolerance from the mean, then the point is regarded as a duplicate. The point that is retained is the one that is closest to the mean.
Creating Declustered Structural Data
To create declustered structural data, right-click on the Structural Modelling folder and select New Declustered Structural Data. Select the source data table and a query filter, if required. Set the parameters and the columns you wish to use, then click OK. The declustered set will be added to the Structural Modelling folder.
You can find more information on the results of the declustering by right-clicking on the declustered set in the project tree and selecting Properties:
The Properties window for a declustered set, reporting how many points it contains and how many duplicate and adjacent points were ignored
Prioritising Values
When a structural dataset has a numeric column that gives some indication of the measurement’s uncertainty, this column can be used to prioritise values. Select the Priority column and set how the values should be handled.
Rows with matching dip and dip-azimuth split into five groups rather than three once the Lithology column is included
Using the Declustered Data
The declustered data can be used like an ordinary structural data table. However, it is a filter on a planar structural data table and can be used as such when the parent table is displayed in the scene. For example, here the filters available for the planar structural data table include the query filters () defined for the table as well as the declustered set ():
The Query filter list for a planar structural data table, offering the declustered set alongside the query filters defined for the table
