Leapfrog Viewer
You can open Leapfrog Viewer scene files in Leapfrog Energy by clicking on the Scene Files tab, then opening one of the scene files in the list.
If the Scene Files tab is not shown in the main Leapfrog Energy window, click on the Leapfrog Energy menu and select Settings. In the User Interface tab, enable the Show Scene Files tab option:
Show Scene Files tab ticked in the Settings window, adding a Scene Files tab to the tab bar
The rest of this topic describes how to work with scene files to display and analyse data.
For information on creating scene files, see Exporting Scenes in the Saved Scenes topic.
The Scene Files tab is organised into a Recent Scenes list and the list of all scene files available in a designated folder:
The Scene Files tab, with a Recent Scenes row of thumbnails above the scene folder path and a row of thumbnails for the scene files in that folder.
Click on the folder button () to change the folder used. This folder is useful if you have one folder in which you keep most of your scene files. Click on the refresh button () to update the list of scenes in the folder.
To open a scene file, click on a thumbnail. Leapfrog Energy will switch to displaying the first scene in the file:
A scene file opened in Leapfrog Geo, with the scene bar and Shapes panel on the left and the first scene in the file, drillholes below a topographic surface, displayed in the 3D view.
Click the scene list to view thumbnails of all the scenes in the file, or use the arrows () to display each scene:
The scene list opened from the scene bar, showing a thumbnail for each of the four scenes in the file.
The Z-Scale setting () shows the scaling of the Z-axis relative to the X- and Y-axes. When the scene file was created, the z-scale may have been set to a value that accentuates height data. For example, this scene has been set to a Z-Scale of 6.0:
An arrow pointing to the Z-Scale reading of 6.0 in the status bar below a scene whose height is exaggerated by that scaling.
The best way to navigate in the 3D scene is using the mouse. If you are using a laptop, it is recommended that you plug in a mouse rather than using the laptop’s touchpad for navigation. However, you can also navigate in the scene using the keyboard.
Action Mouse Keyboard
Changing the viewing angle Click and drag to rotate the scene Press the arrow keys to rotate the scene
For smaller steps, hold down the Shift key while pressing the arrow keys
Zooming in and out of the scene Use the scroll wheel
Hold the right mouse button while moving the mouse
Press the Page Up or Page Down keys
For smaller steps, hold down the Shift key while pressing the Page Up or Page Down keys
Panning the scene Click and hold both mouse buttons, then drag
Hold the scroll wheel and drags
Hold down the Alt key while pressing the arrow keys
Centre an object in the scene Click the scroll wheel
The current viewing angle and scale are displayed in the lower right-hand corner of the scene. Use the Look menu in the toolbar to switch to the different viewing angles:
The Look menu open in the toolbar, listing the viewing angles and their keyboard shortcuts.
If you prefer to navigate using the keyboard, use the keyboard shortcuts shown in the Look menu.
You can display the scene window full screen by clicking on the Fullscreen option in the toolbar ():
The cursor resting on the Fullscreen button in the toolbar, showing the Enter Fullscreen tooltip and its F11 shortcut.
If you have more than one screen attached to your computer, you will be asked which screen to use:
The Fullscreen window asking which monitor to use, with a numbered rectangle for each attached screen drawn at its relative size.
You can display the scene on the larger screen and work with the available objects and scenes on the smaller screen.
Fullscreen mode is useful for presentations with a projector. Select the projector as the full screen monitor, and you will be able to run Leapfrog Energy from the other screen.
Use the controls in the Shapes panel to change how objects are displayed in the scene:
An arrow pointing to the Shapes panel at the left of the window, where each object in the scene has a visibility button, an opacity slider and display controls.
You can hide objects by clicking on the Show/Hide button () and change the opacity of objects using the sliders. Different controls are available to change how the different shapes are displayed. To see what each control does, hold the cursor over it to see the tooltip:
The cursor held over one of the display buttons in the Shapes panel, showing its Show edges tooltip.
When you click on an object in the scene, a popup window will be displayed showing information about the object. If data was included when the scene was created, this will be displayed in the scene. For example, here we can see the selected data point’s location, identification, starting and ending points and lithology:
A drillhole interval clicked in the scene, with an arrow to the popup window listing its location, hole ID, from and to depths and lithology.
If no data is available, only basic location information about the selected shape will be displayed. Here, only the data point’s location is shown:
A shape clicked in a scene created without data, with an arrow to a popup window listing only its location.
