Raster Images
The image file is suitable for importing into GM-SYS Profile Modelling as a bitmap backdrop. The SEG Y data may be projected onto the cross section defined by an existing GM-SYS Profile Modelling model, onto a section defined by the endpoints of the SEG-Y file, onto an arbitrary section manually defined by an origin and azimuth, or displayed using along-line distance with no projection of data. The coordinates for the bitmap corners are written on the bitmap, to make registering the image in GM-SYS Profile Modelling easier.
Raster Image Options
Raster images have several unique configuration options under Process SEG-Y.
