Delete a Layer
From the Layer menu of the main toolbar, select Delete Layer. If no layer is currently active, the Delete Layer dialog will open: select the layer to delete from the Layer drop-down box and press the OK button.
You can also select the layer to delete on the Layers tab of the Model Explorer. Right-click on the layer name and select Delete Layer: a confirmation dialog appears.
When the layer is deleted, the properties of the layer above will be extended through the volume vacated by this layer.
