Change Cross Section VE
This standard Oasis montaj function enables you to change the X and Y scales of a view on the current map.
To Change the Cross Section VE
Before you begin, confirm the cross-section map is the current map.
  1. On the Display menu, select Change Cross Section VE. The Select Data View dialog appears.
  2. From the dropdown list, select the Data view "STACK_0" which contains the cross-section data.
  3. Click OK. The Set View X and Y Scaling dialog appears.
  4. Specify the scaling. Typically Y Scale will be an even multiple (vertical exaggeration) of the X Scale.
  5. Click OK. The cross-section is rescaled within the map. You may need to redraw the map or select "Full View" to see the rescaled section in its entirety.
