Magnetic Forward Calculation
The Forward Magnetic function performs a forward magnetic calculation of the model currently active. You may specify an “inline filter” that will be applied to the calculated result. Filters can be created using the GX.Net tool (geogxnet.dll(Geosoft.GX.FFT2D.MAGMAPFiltering;Run)) from the 2D Filtering > MAGMAP Filtering Oasis montaj menu.
Perform Forward Magnetic Calculation
On the Calculate menu, select Forward Magnetic. The 3D Magnetic Forward Calculation dialog appears.
In the dialog, enter a value in the Number of Taylor Series Terms field. This is the number of terms in the Taylor series calculation. It must be an odd number, greater than or equal to 3. The default is 5.
Click OK. The progress bar appears and the calculation is processed.
