Export Solutions to New GM-SYS Model
The Pdepth > Export Solutions to New GM-SYS Model option (GMSMODSOL GX) is a GX wrapper for Export Solutions for GM-SYS and Export Profiles to GM-SYS. Export Solution for GM-SYS extracts the Pdepth solutions from the current database into
Export Solutions to New GM-SYS Model dialog options
File name root |
Root of output file name. The line # will be appended to this root name to generate the filename. |
Magnetic channel |
The database channel containing the magnetics values on which the depth solutions are based. |
Solutions channel |
The database channel containing the depth solution flags on which the symbol file will be based. |
Distance units |
The units of measure to be used in the GM-SYS Profile Modelling model(s). |
Horizontal values |
"Depths" mean z+ down, "Elevations" mean z- down. This value will be passed on to GMSMULTI.GX. |
This GX is a wrapper which runs GMSXSOL.GX, creating the
