Importing Data from an ESRI File Geodatabase
You can import points, lines and polygons from an ESRI file geodatabase. However, the import of raster data is not supported.
To import GIS points, lines and polygons in this way, right-click on the GIS Data, Maps and Photos folder and select Batch Import > from ESRI Geodatabase. In the window that appears, navigate to the folder that contains the database folder (*.gdb) and click Open.
Leapfrog Geo imports uncompressed ESRI geodatabases.
The data that can be imported will be displayed and you can select which files to import:
You can select multiple files using the Shift and Ctrl keys.
Click OK to import the selected files, which will be added to the GIS Data, Maps and Photos folder as a group (
). Data in the group can be reloaded individually or as a group, which is described in Reloading GIS Data.
