Splitting Lithologies
With the split lithologies tool, you can create new units from a single unit by selecting from intervals displayed in the scene. When you split lithologies, the original lithology column is preserved and a new lithology column is added to the interval table. You can then select the original lithology column or the new one when displaying data and creating models.
The difference between the interval selection tool and the split lithologies tool is that with splitting lithologies, you are limited to selecting intervals from a single lithology. If you wish to select intervals from multiple lithologies, see Selecting Intervals.
To start splitting a lithology, first add the drilling data to the scene. Then right-click on the interval table in the project tree and select New Column > Split Lithologies. The New Lithology Column window will appear:
The Lithologies and Splits window will appear, together with a set of tools that will help you to select intervals in the scene:
Alluvium (gold) appears both above and below Coarse Sand (blue) and so should be split into two separate lithologies.
The first step is to select the lithology that will be split in the Lithologies and Splits window. In the example above, Alluvium is already selected.
Next, click on the Select Intervals tool (
) and click the Add Intervals tool (
). In the scene, draw a line across each interval you wish to select.
To change the width of the line used to select intervals, click on the Change line width button (
You can also:
) or by pressing Ctrl+I.
Once you have selected some segments, click on the Assign to button in the Lithologies and Splits window and select Create New Split:
The New Split window will appear:
Enter a Name for the new lithology, then click OK. The new lithology will be created and the scene updated to reflect the changes:
When you delete a lithology from the list, all intervals that have been assign to that lithology will revert to the lithology assigned in the Base Column.
) and close the Lithologies and Splits window. The new lithology column will appear in the project tree as an additional lithology column in the interval table.
Select the new column from the shape list to display it:
Click on the Edit button (
) to start editing the selected column.
