Structural Data
In Leapfrog Geo, you can create and edit planar structural data tables directly or from other objects in the project. Structural data can also be used to create and edit many surfaces. Downhole planar structural data and lineations can also be imported, although structural data imported in this way cannot be edited.
This topic describes how to work with structural data in Leapfrog Geo. It covers:
- Importing Lineations
- Displaying Structural Data
Leapfrog Geo calculates strike using the American right-hand rule; when looking in the strike direction, the plane should dip to the right.
There are two ways to create a new planar structural data table in Leapfrog Geo:
- Create a new table as part of creating or editing another object. See Editing Surfaces With Structural Data.
Leapfrog Geo supports planar structural measurements in the following formats:
- ASCII Text Files (*.asc)
- CSV Text Files (*.csv)
- Data Files (*.dat)
- Plain Text Files (*.txt)
- TSV Text Files (*.tsv)
This topic describes importing structural data tables that include location information. Downhole structural data can also be imported, as described in Importing Drilling Data in the Importing Drilling Data topic.
- Files stored on your computer or a network location. Right-click on the Structural Modelling folder and select Import Planar Structural Data. You will be prompted to select a file.
- From any database that runs an ODBC interface. Right-click on the Structural Modelling folder and select Import Planar Structural Data via ODBC. See Selecting the ODBC Data Source below.
For each of these options, once the data source is selected, the process of importing the data is the same. Leapfrog Geo will display the data and you can select which columns to import:
Leapfrog Geo expects East (X), North (Y), Elev (Z), Dip and Dip Azimuth columns. The Polarity column is optional. The Base Category column can be used for filtering data once it has been imported.
Once the data has been imported, you can add new columns and rows and reload the data, which is described in the Working With Data Tables topic.
Lineations containing location information can be imported from files stored on your computer or a network location in the following formats:
This topic describes importing lineation files that include location information. Downhole lineations can also be imported, as described in Importing Drilling Data in the Importing Drilling Data topic.
To import a lineations file containing location information, right-click on the Structural Modelling folder and select Import Lineations. You will be prompted to select a file.
Leapfrog Geo expects East (X), North (Y), Elev (Z), Trend and Plunge columns. The Polarity column is optional. The Category column can be used for filtering data once it has been imported.
Once the data has been imported, you can add new columns and rows and reload the data, which is described in Adding and Updating Data for Existing Tables in the Working With Data Tables topic.
The categories displayed can also be filtered by other columns in the data table, as described in Using the Display Filter.
Bingham Analysis
Fisher Statistics
There are two ways to initiate structural data selection: from the data object in the project tree/shape list and from a stereonet. The advantage of initiating structural data selection from a stereonet is that the data will be displayed both on the stereonet and in the scene window. This provides the most flexibility for analysing what data belongs to what category. See Selecting Data in the Stereonet and Using the Scene Window With the Stereonet for more information.
- Edit the data in the table directly by double-clicking on the structural data table in the project tree. See Working With Data Tables.
Unprojected points are data points that do not vertically intersect the selected surface. There are three options:
