Filtering Data in the 3D Scene
When data tables are displayed in the 3D scene, there are two ways of filtering data to aid interpreting the data. These are:
Filtering Data Using Queries
In Leapfrog Geo, you can define query and volume filters for data tables that select a subset of data for future processing; this is described in the Filtering Data topic. Filters can also be used when displaying data in the scene.
To apply a filter to the scene, select the object in the shape list, then select the filter from the Query filter list in the shape properties panel. For drilling data, any defined volume filters can will also be displayed in the Query filters list.
Choosing a query filter for a table in the shape properties panel, listing the filters defined on the collar table
For a drilling data table, this displays only the data selected by the filter. The trace lines remain displayed in the scene. To filter out the trace lines so they are not displayed in the scene, tick the Filter trace lines box:
The Filter trace lines checkbox ticked so that trace lines are hidden along with the filtered-out data
Using the Display Filter
In the shape properties panel, you can also filter the range of values displayed. In the Display filter field, select the column to use as the value range filter. It does not need to be the same column as that selected in the shape list. Tick the Enable filter box to apply the filter or untick the box to stop using the display filter without discarding your filter selection settings. This allows you to turn the filter on and off easily, without having to redefine the filter each time.
If the column you select for the Display filter is a numeric column, a range slider will be displayed for selecting the values to filter:
A numeric column chosen as the Display filter, with a range slider and value boxes for setting the lower and upper bounds
The lower and upper value bounds can be set by dragging the handles at each end of the range slider, or by entering values into the boxes above the range slider.
A range slider in coarse control mode, shown dark blue with its handles at each end covering the full range of 1 to 160
The same range slider with its handles dragged in to restrict the range to 1 to 50
Dragging the selected section of a range slider to move the displayed range along, here to 52 to 101
Double-clicking a range slider switches to fine control, expanding the selected range of 52 to 101 across the whole slider
In fine control mode, moving the handles inwards further restricts the range from 52 to 101 down to 60 to 80
Right-clicking a range slider returns it to coarse control, restoring the earlier range of 52 to 101
If the column you select for Display filter is a category column, the options for selecting the values to filter will look like this:
A category column chosen as the Display filter, with Select Categories opening a legend where each category can be shown or hidden
Click the Select Categories button to open a dialog that will allow each individual category to be shown or hidden.
If the column you select for Display filter is a date/time column, the options for selecting the values to filter will look like this:
A date/time column chosen as the Display filter, with date buttons above the range slider that open a date picker
The lower and upper value bounds can be set by dragging the handles at each end of the range slider, or by clicking the date buttons above the range slider, which will open a date-picker dialog.
When the range slider is set to a portion of the whole value range, it can be clicked and dragged to move both the lower and upper limits by the same amount. This is handy when specifying a particular window which you can then drag across the whole range to observe the effect in the scene.
These range sliders have a feature that helps with fine refinement of the value range selection. Double-click on the range slider:
A narrow range selected on a dark blue range slider whose full extent runs from 0.02 to 9.29, with the cursor on the slider ready to double-click
The slider will change to a pale blue and while the lower and upper limits remain the same, the slider has changed to fill the whole width of the shape properties panel.
After double-clicking, the slider changes to pale blue and the selected range of 1.54 to 3.347 is stretched across its whole width
You can then manipulate the lower and upper end points, and because the range has been restricted, you have finer-grained control as you move the range slider handles.
With the range expanded across the slider, the handles can be moved for finer control, here narrowing the range to 1.673 to 3.112
You can double-click the range slider to zoom in even further for higher resolution control.
The cursor on the range slider, ready to double-click again and zoom in further for higher resolution control
To return to the previous level of range selection, right-click the range slider.
Zoomed in a further level, with the range 1.673 to 3.112 now filling the whole slider
Repeat the right-click on the range slider again to go back another level.
Right-clicking has stepped the slider back one zoom level, to the range 1.54 to 3.347
When you get back to the original range selection zoom level , the range slider will change back to dark blue.
Right-clicking again returns the slider to its original zoom level, shown by the dark blue bar spanning 0.02 to 9.29
Right-clicking the range slider at this point will revert the range selection to the full value range.
A final right-click reverts the selection to the full value range of 0.02 to 9.29
