Importing Block Models
You can import the following types of block models into Leapfrog Geo:
  • Regular block models
  • Octree sub-blocked models
  • Fully sub-blocked models
The formats supported depend on the type of block model you are importing.
  • Surpac *.mdl format:
  • CSV + Text Header (*.csv, *.csv.txt) and CSV with Embedded Header (*.csv) formats:
Variable Z sub-blocked models cannot be imported into Leapfrog Geo projects.
Regardless of the file and model type, start importing by right-clicking on the Block Models folder and selecting Import Block Model.
Right-clicking the Block Models folder and selecting Import Block Model.
In the window that appears, select the file you wish to import, then click Open. Leapfrog Geo will open the file and step you through the import wizard, which is different for Surpac and CSV files. See:
Importing Surpac *.mdl Block Model Files
If you are importing a regular block model or an octree sub-blocked model from a Surpac *.mdl file, the following Import Block Model window will appear:
The Import Block Model window for a Surpac file, with all the data columns in the Selected list.
By default all data columns will be in the Selected list, but you can choose to move some out to the Available list if you do not wish to import them. Click OK and the *.mdl file will be imported.
Importing CSV Block Model Files
Leapfrog Geo can import CSV block models with regularly sized blocks or with sub-blocks that conform to multiples of a defined minimum cell size. This includes block models produced by Leapfrog, as well as by other mining GMPs (e.g. Surpac, Datamine, Vulcan, Minesight). If you are importing a block model in CSV format, the Import Block Model window will prompt you to select the type of block model you are importing:
Choosing the type of block model held in a CSV file, with the file contents shown alongside.
Sub-blocked models that have merged cells can be imported into Leapfrog Geo. The merged cells will be expanded into the component sub-block cells. When subsequently exported, the model will be exported with the expanded component sub-block cells, without merging them back together.
If Leapfrog Geo is able to detect what sort of block model was stored in the file, that option will automatically be selected.
This window also includes a preview of the file to aid in selecting the type of block model.
Once you have selected the model type, there are two steps to finishing the import:
Selecting Attributes
After selecting the block model type and clicking Next, you will be presented with a window to Select Attributes to import. Here you can make sure all the columns you want to import are selected and have appropriate Column type and Import Name settings.
The Select Attributes step, where each column's type and import name are checked before importing.
Click Next when you have completed selecting the attributes to import from the file.
Defining the Grid
The Grid Definition fields for an imported block model cannot be modified once the block model has been imported.
In the Grid Definition window, data from the CSV will be used to define the model’s block size, position and extents.
The Grid Definition step for a regular block model, with the file contents shown alongside.
For sub-blocked models, the Blocks section has some additional details relating to sub-blocking:
The extra Sub-block count and Minimum size details shown in the Blocks section for a sub-blocked model.
The source data is displayed on the right to help you in setting these properties.
The Metadata tab on the right side of the screen will contain additional information extracted or processed from the file content, including the minimum and maximum grid corners were the grid not rotated.
The Metadata tab, listing the unrotated grid corners, the block sizes found in the file and the derived sub-block count.
The grid definition is divided into:
While the grid definition does not align with the block centroid points, a message will warn that none of the blocks in the file match the grid you’ve defined.
The error shown when no blocks in the file match the grid definition.
When the grid definition provides a match with some but not all the blocks, the message changes to a warning that without further changes, the file may not import properly. This usually indicates that the grid definition is close to correctly matching the data in the file, but there may be a small change required to improve the definition.
The warning shown when only some of the blocks in the file match the grid definition.
When the grid definition aligns with the data in the file, the message changes to inform you that all the blocks in the file match the grid you’ve defined.
The message shown when every block in the file matches the grid definition.
If no grid definition header is apparent for the file you have selected, check the source folder to see if there is another file that contains the grid definition information.
If a block model was exported from Leapfrog Geo, the file will be named the same but also have “.txt” at the end.
If Leapfrog Geo can identify the sidecar file, it will be displayed in a tab on the right side of the window.
A text sidecar file holding the grid definition, shown in its own tab beside the CSV file.
Note that importing a block model in CSV format does not require a header in either the CSV file itself or any text sidecar file. Once you start the import process, Leapfrog Geo will use the data in the file to locate the minimum and maximum centroids. You can view this information and change how the data is mapped before the file is imported into the project.
If the naming conventions used in the block model definition data can be interpreted by Leapfrog Geo, those values will be automatically imported into the appropriate grid definition fields. Here is an example showing how fields for a regular block model have been automatically populated:
Grid definition fields for a regular block model populated automatically from the header in the file.
Here is an example showing how the fields for a sub-blocked model have been automatically populated:
Grid definition fields for a sub-blocked model populated automatically from the header in the file.
It is possible to manually populate the details in the grid definition, and this may be necessary if Leapfrog Geo cannot determine the correct location for the model definition data in the file. To make the process easier, the grid definition window lets you select and drag data from the right side of the window onto grid definition fields on the left side of the window.
  1. Select a number or a series of numbers from the file data on the right side of the screen.
You can include other text such as the data labels or separator symbols.
  1. When the data is highlighted, click-and-drag the highlighted text toward the left side of the screen.
As the cursor passes over fields that can accept the data, the fields that can accept the data will be highlighted with a blue box. If you have selected several numbers, you will see several adjacent fields being highlighted with a blue box at the same time.
  1. Release the mouse button to drop the data into the highlighted field or fields.
If you cannot drop the selected data into the current location, the mouse cursor will indicate that this is not possible, showing a red circle with an oblique line through it.
Animation showing values selected in the file listing and dragged onto the grid definition fields, with the target fields highlighted.
For files containing regular block models with no missing centroids, but which do not have a grid definition header or any available sidecar file, Leapfrog Geo will attempt to auto-fit a grid definition to the data. If Leapfrog Geo is successful in auto-fitting the grid definition, informational messages like these will appear at the bottom of the import window:
The messages shown when Leapfrog Geo has auto-fitted a grid definition to a file with no header.
The grid definition that Leapfrog Geo finds may not match the original grid definition, as there will be multiple possible grid definitions that will match the data, although the base point, rotation details and i,j, and k indices will be different for each possible definition. If the base point for the block model is known, the source file can be edited to put that centroid as the first row in the file to force the identification of the base point to a specific centroid.
If your block model file has no grid definition parameter data and it contains a sub-blocked model or has missing centroids, you can attempt to manually align the grid definition using points in the scene as a guide.
If you manually align the imported model to a grid definition, even if the importer reports that “all the blocks in the file match the grid you’ve defined” the resulting block model cannot be guaranteed to be the same as the block model exported to file. If at all possible, obtain the actual grid definition parameters and enter these parameters in the importer.
Drag the grid definition window aside to see the scene and you will see points representing the block model centroids, along with an outline for the current grid definition. This may assist in manual entry of the grid definition.
The grid definition window moved aside to show the block centroids and the current grid outline in the scene.
When you have successfully specified the grid definition to align with the file data, click Finish. The block model will be imported from the CSV file and will appear in the Block Models folder.
You can apply new triggers and evaluations to imported block models.
