Polarity in Leapfrog Geo
Polarity refers to which side of an object is considered the “inside” or “outside”, or the “younger” or “older” side. When used correctly, polarity is a useful tool for controlling structurally complex surfaces, defining how custom boundaries are applied to models or controlling how meshes are clipped during mesh operations. Object polarity can cause unexpected or confusing results if the polarity of an object is different to what was intended or expected.
Polylines, surfaces and structural data all have polarity in Leapfrog Geo.
Polarity and Polylines
When a polyline is drawn on a two-dimensional plane such as the slicer, the orientation of the polyline will be consistent. When a polyline is drawn on a three-dimensional object, however, each segment in the polyline will have a different “in” and “out” orientation. To see the line polarity, and the polyline to the scene and increase the Ribbon width so a clear ribbon extends away from the polyline. This will help you to see not only how a line changes direction, but also how it twists. You can view the Surface ribbon () as shown here:
A spiral polyline on a mesh with the Surface ribbon display selected, its ribbon twisting between red and blue faces along the coils, and Ribbon width set to 32 pixels
Or you can choose the Normal ribbon (), which depicts the ribbon at the normal (or, right angles to) the Surface ribbon view:
The same spiral polyline with the Normal ribbon display selected, the ribbon now presented flat-on as a broad red band around each coil
Invert Polyline Polarity
If the whole line has the wrong polarity, you can select the line then click the Flip selected objects button ().
Adjust Polyline Polarity Using Tangents
To adjust a portion of a polyline, one tool you might choose is the Add or set tangents at the selected points, from the current viewing angle button (). Click on the line where you would like the tangent inserted, then click the () button. This will add a tangent pointed directly away from the current viewing perspective, and whole line will be twisted so the surface ribbon is aligned in the direction of the viewing angle also, up to the point that some other part of the ribbon has an existing tangent set (if any).
The add-tangent toolbar button highlighted, with an arrow from the selected point on the spiral to an inset view showing the tangent cone now pointing toward the viewer
To achieve the desired result, you may need to reposition the viewing angle and set additional tangent points.
The spiral polyline with a dozen green tangent cones set around it, the ribbon now consistently red along every coil
Imported polylines can often have inconsistent polarity across different parts of the polyline, which can limit their usefulness until the polarity issues are addressed. Observe how a inverted polarity direction in one part of a polyline can affect a mesh built from the polyline:
A polyline with a section of inverted polarity producing a contorted, folded mesh, compared below with a consistent polyline producing a smooth mesh
If you are editing a surface with a polyline and you get an unexpected result such as the one shown above, check the polarity of your polyline disks.
Polarity and Surfaces
Almost every mesh added to the scene in Leapfrog Geo, including meshes from the Meshes folder or surfaces from a geological model, will have one colour on one side of the surface and a different colour on the other side. This represents the polarity of the surface, identifying what is considered the ‘outside’ and the ‘inside’ of the surface. Note that numeric model isosurfaces and form interpolant surfaces do not have polarity.
When a surface from the Meshes folder is added to the scene, by default the colouring is red for the inside and blue for the outside of the mesh.
A topographic mesh in the scene showing red on the inside face and blue on the outside face
When a surface from a geological model is added to the scene, the colours reflect the relevant unit colours defined by the drilling data, and the polarity represents the “younging” side. Here two surfaces separating some stratigraphic layers are revealed, and each side of the surface is coloured by lithology:
Two contact surfaces in a geological model, each side coloured by the lithology it faces, with the model's lithology legend at the right
In addition to the surfaces being displayed coloured by the lithologies assigned to each side, they can also be displayed by their younging direction, which is shown here, where the green side is the younger side and the brown side is the older side:
Stratigraphic contact surfaces displayed by younging direction, green on the younger side and brown on the older side, with the shape list colouring set to Younging
Polarity and Structural Data
The polarity of structural data is also indicated by the colouring of the disk sides. The orientation of a structural data disk is initially set when it is drawn, according to the direction the mouse was dragged after clicking on the place to insert the disk:
A new structural data disk being drawn on a geological map, with a red arrow showing the drag direction that sets its orientation and two completed disks nearby
Then the tilt of the disk is set in the Planar Structural Data window. Note also the Flip Polarity button to invert the orientation of the disk if the disk was accidentally drawn in the wrong way.
The Planar Structural Data window showing dip and dip azimuth for a point, with Flip Polarity below and tilt handles on the disk in the scene
Consistency of polarity is important to get a consistently oriented surface created from the structural data, a surface with a clear ‘inside’ and ‘outside’.
A smooth, gently curved surface built from structural data disks that all share the same polarity, shown by their matching red faces
Where structural data has been placed with inconsistent polarity, any resulting surface will have a contorted and inappropriate shape due to unclear ‘inside’ and ‘outside’ directions. If you are editing a surface with structural data and you get an unexpected result such as the one shown below, check the polarity of your structural data disks.
A contorted, double-lobed surface produced by structural data disks of inconsistent polarity, with some disks showing red faces and others blue
