Category Composites
In Leapfrog Geo, you can composite category data in three ways:
  • Composite the drilling data directly as a category composite. This creates a new interval table with primary, exterior and ignored intervals that can be used to build models, and changes made to the table will be reflected in all models based on that table. This process is described below.
  • Composite the drilling data directly as a category simplify composite. This creates a new interval table using the existing category codes, but simplifying and consolidating intervals. To learn about this compositing tool, see the Category Simplify Composite topic.
  • Composite the points used to create an object; an example of this is when you create a contact surface in a geological model and such a surface can have its own compositing settings.
Creating a Category Composite
Right-click on the Composites folder, which is in the project tree as part of each drilling dataset, and select New Category Composite. You will be prompted to select from the category columns available in the drilling data. Next, the New Composited Table window will appear, showing the options for sorting intervals in the selected column:
The New Composited Table window, with the primary unit chosen at the top, lists that sort the remaining units into exterior and ignored segments, and the compositing length settings below.
  • Primary. This is the unit of interest.
  • Ignored. These are units that are, generally, younger than the unit of interest and should, therefore, be ignored in generating contact surfaces.
  • Exterior. These are units that occur outside of the unit of interest. For an intrusive lithology, other lithologies the intrusion contacts should be classified as Exterior.
Converting Ignored Segments
The Convert enclosed ignored segments setting determines how ignored segments are handled when they are flanked by either two interior segments or two exterior segments. If Convert enclosed ignored segments is enabled, Leapfrog Geo will convert enclosed ignored segments to match the surrounding segments. In cases where an ignored segment does not lie between two interior or exterior segments, it will remain ignored.
Convert enclosed ignored segments left unticked, so the two pale segments boxed in the composited drillhole are still keyed to Ignored in the legend.
Convert enclosed ignored segments ticked, so the same two boxed segments are now keyed to Primary in the legend.
Shorter than enabled and set to 3, so only the shorter of the two boxed segments is keyed to Primary and the longer one stays Ignored.
A short exterior segment in the composited drillhole, arrowed to show that it has not been converted.
Where ignored segments are at the end of the drillholes and thus have no primary unit on the other side to enclose them, the ignored segments are not converted:
Pale segments boxed at the ends of two composited drillholes, keyed to Ignored because there is no primary unit beyond them to enclose them.
Convert primary segments shorter than set to 2, with the affected drillhole segments boxed and keyed to Exterior in the legend.
The same setting raised to 7, where a boxed length of drillhole is keyed to Exterior but the primary segment enclosed by ignored segments is not converted.
Convert exterior segments shorter than set to 2, with three short boxed segments keyed to either Primary or Exterior depending on what adjoins them.
The Converted primary/exterior segments must be enclosed setting is useful for situations where a primary or exterior segment is bounded on only one side by another segment type. For example, here we have original drilling (in blue, green and red) shown inside composited drillholes. There are eight composited drillholes (highlighted) where exterior segments have been converted into primary segments, despite only being bounded by the primary lithology on from above:
With Converted primary/exterior segments must be enclosed unticked, four boxed places where the composited holes extend the primary lithology below the original contact.
With Converted primary/exterior segments must be enclosed ticked, the same four boxed places keep the original contact instead of extending the primary lithology.
To see how these parameters can smooth the shape of a unit of interest, let’s look at a series of drillholes where we wish to create an intrusion boundary based on the red segments. Short segments are highlighted in the intervals that have not been composited:
Uncomposited drillholes with red intervals in blue, where four very short intervals are boxed.
The same drillholes after compositing, with the short intervals absorbed so each hole carries only a few clean red and blue lengths.
The Choose Statistics Type window offering Table of Statistics, Scatter Plot, Q-Q Plot, Box Plot and Interval Length Statistics.
See the Saved Statistics topic for an introduction to statistics in Leapfrog Geo.
The Interval Length Statistics graph is a univariate graph, so for more information on the options available, see the Univariate Graphs topic.
