Basic Stratigraphy
The Basic Stratigraphy tool is intended for geology where the bedding is relatively planar with little to be managed in the way of pinchouts.
This topic describes using the Basic Stratigraphy sequencing tool and is divided into:
Creating a Stratigraphic Sequence
To create a basic stratigraphic sequence, right-click on the Surface Chronology object and select New Stratigraphy > Basic Stratigraphy. The New Stratigraphic Sequence window will appear:
The New Stratigraphic Sequence dialog as it first appears, with an empty Stratigraphic Lithologies list and both Lithology Above and Lithology Below set to Unknown
Select the lithologies at the top and bottom of the stratigraphic sequence. To do this, select the Lithology Above and Lithology Below from the lithologies available in the geological model:
Choosing the Lithology Above from the geological model's lithologies in the New Stratigraphic Sequence dialog.
You can add lithologies to the Stratigraphic Lithologies list first, but if you set the Lithology Above and Lithology Below first, those lithologies will be filtered out when you select the Stratigraphic Lithologies.
Next, click the Add button () to view available lithologies:
Clicking the add button opens the Select Lithologies dialog, listing the lithologies available for the stratigraphic sequence with a checkbox against each.
Select the lithologies that you want to use in the stratigraphic sequence, then click OK to add the layers to the Stratigraphic Lithologies list. Make sure they are arranged in the correct order, using the arrows alongside the window to rearrange them, if necessary:
The Stratigraphic Lithologies list filled in, with an arrow pointing to the up and down buttons used to put the layers in the correct order.
In the New Stratigraphic Sequence window, select whether the Bottom Contact Type is an erosion or a deposit.
When the Surfaces avoid drillhole segments option is enabled, the surfaces in the stratigraphic sequence will not cut through intervals of lithologies that are selected for the stratigraphic sequence.
Next, click on the Surfacing tab to set the surfacing settings for each surface created for the sequence:
The Surfacing tab for a stratigraphic sequence, with boundary filter, snapping, resolution inherited from the geological model, and a surface stiffness slider.
For the Boundary filter and Snap to data options, it is possible to override these settings for the individual contact surfaces that are part of the stratigraphic sequence. To do this, select Custom. Once the stratigraphic sequence has been created, expand it in the project tree and double-click on each surface to change its surfacing options, as described in Contact Honouring and Boundary Filtering for Individual Surfaces below.
Boundary Filtering
  • Filter the data. The surface is only influenced by the data that falls inside the surface’s boundary.
  • Leave the data unfiltered. The surface is influenced by the data both inside and outside the surface’s boundary.
  • Inherit from GM. The setting for the geological model as a whole is used. This is the default setting.
  • Off. Data is not filtered.
  • All data. All data is filtered.
  • Drilling only. Only drilling data and data objects derived from drilling data are filtered.
  • Custom. Only the data objects specified in the Inputs tab are filtered.
All contact surfaces that make up a stratigraphic sequence will inherit the Boundary filter setting from the stratigraphy unless Boundary filter is set to Custom.
Snapping to Data
For a stratigraphic sequence, the options are:
  • Off. Surfaces do not snap to the data used to create them.
  • All data. Surfaces snap to all data within the Maximum snap distance, which includes drilling data and any data added to the surfaces.
  • Drilling only. Surfaces snap to drilling data and data objects derived from drilling data within the Maximum snap distance but not to other data used to modify the surfaces.
  • Custom. Surfaces snap to the data objects indicated in the Inputs tab for each surface.
All contact surfaces that make up a stratigraphic sequence will inherit the Snap to data setting from the stratigraphy unless Snap to data is set to Custom.
Surface Stiffness
The Surface Stiffness controls the smallest bend a surface will make, where a higher value will result in a smoother surface that bends less. The default value is 0, which is no stiffening.
Click OK to create the stratigraphy, which will be added to the project tree as part of the Surface Chronology object.
Editing the Stratigraphic Sequence
The objects that make up the stratigraphic sequence include the generated contact surfaces and any points that result in pinch-out errors:
A stratigraphic sequence expanded in the project tree, with an arrow pointing to the Pinch-out Errors object above the generated contact surfaces.
Correcting Pinch-Out Errors
Add the pinch-out errors object () to the scene to view the points that are causing errors. To find out more about the errors, either:
  • Right-click on the stratigraphic sequence and select List Errors
  • Double-click on the pinch-out errors object ()
In the Stratigraphic Errors window, information is provided about the different errors that occur in the stratigraphic sequence, with pinch-out errors and other errors listed separately:
The Stratigraphic Errors dialog, listing pinch-out errors with the lithologies that touch and the pinched-out lithology, and other errors in a separate table below.
Use this information, together with the pinch-out error points, to either remove lithologies from the sequence or adjust surfaces using any of the tools available for individual surfaces, as described in Editing Individual Surfaces below.
Remove lithologies from the sequence by double-clicking on the sequence in the project tree, then reorganising the lithologies in the Chronology tab.
You can also ignore an error by ticking the Ignored box in the Stratigraphic Errors window.
Surfacing Options
To change a stratigraphic sequence’s surfacing options, double-click on the sequence in the project tree and click on the Surfacing tab. See Boundary Filtering and Snapping to Data above for more information on the settings in this tab. Note that boundary filtering and snap settings can also be set for the individual surfaces that make up the stratigraphic sequence, which is described in Contact Honouring and Boundary Filtering for Individual Surfaces below.
Applying a Trend
To apply a global trend to a stratigraphic sequence either right-click on it in the project tree and select Adjust Surface or double-click on the stratigraphic sequence and then click on the Trend tab. You can then apply a trend to the surface as described in the Setting a Global Trend topic.
Individual surfaces that make up a stratigraphic sequence can be modified by:
There are general boundary filtering and snap settings for the stratigraphic sequence as a whole, but it is possible to override these settings for the individual surfaces that are part of the stratigraphic sequence. To do this, first double-click on the stratigraphic sequence itself, then click on the Surfacing tab.
  • To change boundary filtering for an individual surface, Boundary filter must be set to Custom for the stratigraphic sequence.
  • To change the snap setting for an individual surface, Snap to data must be set to Custom for the stratigraphic sequence.
Next, double-click on an individual surface in the project tree. The window that appears shows all the data objects used to create the surface:
The Edit Stratigraphic Surface dialog, listing the data objects used to create the surface with per-object Snap and Boundary filter checkboxes.
See Boundary Filtering and Snapping to Data for more information.
Adding Data to Individual Surfaces
You can also refine the individual surfaces in a stratigraphic sequence in several ways:
  • Add other data. Right-click on the surface to see the options available, which will depend on how the surface was created. See Adding Data to Surfaces for more information.
  • Edit the surface with a polyline. Right-click on the surface in the project tree and select Edit > With Polyline. See Editing Surfaces With Polylines for more information.
It is not possible to add structural data or polylines with orientation information to individual surfaces in a stratigraphic sequence. If you edit a surface with a polyline, your options for editing the polyline will be limited.
Editing Surface Contacts
You can edit the contacts used to generate the surface by expanding the contact surface in the project tree and double-clicking on the points object (). See Extracting Contact Points from Drilling Data for more information on the settings in the Edit Contacts window.
