Indicator RBF Interpolants
An indicator RBF interpolant is a useful way of creating a region of interest in which further processing can be carried out. For example, you can use an indicator RBF interpolant to define a volume that encloses the values that are likely to be above a cut-off threshold and then use the volume as a boundary or domain to carry out further processing inside that volume. Or you might use the indicator RBF interpolant to temper the effects of extreme high-grade samples combined with sparse drilling; as all the samples are converted into either 0s or 1s, the resulting volume produced tends to be more conservative with fewer ‘blow-outs’.
Any small, uneconomic volumes that are the result of the indicator interpolant process can be automatically removed using a minimum volume filter, and a statistics tab provides detailed statistics on how the model overlaps with other data in the project.
The rest of this topic describes how to create and modify indicator RBF interpolants. It is divided into:
Creating an Indicator RBF Interpolant
To create an indicator RBF interpolant, right-click on the Numeric Models folder and select New Indicator RBF Interpolant. The New Indicator RBF Interpolant window will be displayed:
The New Indicator RBF Interpolant window, where the values, cut-off, compositing, boundary and iso value for a new indicator interpolant are set
The New Indicator RBF Interpolant window is a simpler version of the Edit Indicator RBF Interpolant window. While the Numeric values object selected when the interpolant is created cannot be changed later, all the other settings, and more, can be modified. The edit window also has features to assist value selection, such as a histogram to aid selecting a cut off value. If you are unsure of any setting, accepting the default value Leapfrog Geo proposes is a good option for creating a first-pass indicator interpolant. You can then modify the values in the edit window as you iterate to improve the model.
This window is divided into four parts in which you select the values used to create the interpolant, the interpolant boundary, any compositing options and general interpolant properties.
Selecting the Values Used
In the Values To Interpolate part of the New Indicator RBF Interpolant window, select the values that will be used and choose whether or not to filter the data and use a subset of those values in the interpolant.
You can build an indicator RBF interpolant from either:
  • Numeric data contained in imported drilling data.
  • Points data imported into the Points folder.
You cannot change the Values To Interpolate setting once the interpolant has been created.
Setting the Cut Off
The Cut-off value will be used to generate sample points and create two output volumes:
  • An Inside volume that encloses all values likely to be above or equal to the Cut-off value.
  • An Outside volume that enclose all values likely to be below the Cut-off value.
The probability that the enclosing volume encloses values above the cut-off is set by the Iso value.
The General section of the window with the Iso value field, set to 0.5, highlighted.
If you are unsure of what Cut-off value to use, you can view statistics on the distribution of the data and change the Cut-off value once the interpolant has been created. Double-click on the indicator RBF interpolant in the Numeric Models folder to open the Edit Indicator RBF Interpolant window and switch to the Cut-off tab.
You can also change the names of the Inside and Outside volumes once the interpolant has been created.
Applying a Query Filter
If you have defined a query filter and wish to use it to create the interpolant, select the filter from the Query filter list. Once the model has been created, you can remove the filter or select a different filter.
Applying a Surface Filter
The Interpolant Boundary
  • Enter values to set a Custom boundary.
  • Use the controls in the scene to set the Custom boundary dimensions.
  • Select another object in the project from the Enclose Object list, which could be the numeric values object being interpolated. The extents for that object will be used as the basis for the Custom boundary dimensions.
  • Select another object in the project to use as the Interpolant Boundary. Click the Existing model boundary or volume option and select the required object from the list.
Once the interpolant has been created, you can further modify its boundary. See Modifying an RBF Interpolant’s Boundary With Lateral Extents and Adjusting the Interpolant Boundary in the RBF Interpolants topic for more information.
Compositing Options
When numeric values from drilling data are used to create an interpolant, there are two approaches to compositing that data:
  • Composite the drilling data, then use the composited values to create an interpolant. If you select composited values to create an interpolant, compositing options will be disabled when you first create the interpolant and there will be no Compositing tab when you edit the interpolant.
  • Use drilling data that hasn’t been composited to create an interpolant, then apply compositing settings to the interpolated values. If you are interpolating values that have not been composited and do not have specific Compositing values in mind, you may wish to leave this option blank as it can be changed once the model has been created. You can also change whether or not you use compositing once the interpolant has been created in the interpolant’s Compositing tab.
Set the Surface resolution for the interpolant, whether or not the resolution is adaptive and whether or not the interpolant uses single-pass isosurfacing. See Surface Resolution in Leapfrog Geo for more information on the effects of these settings. The resolution can be changed once the interpolant has been created, so setting a value in the New Indicator RBF Interpolant window is not vital. A lower value will produce more detail, but calculations will take longer.
An indicator RBF interpolant produces a single isosurface that is used to determine the likelihood of values falling inside or outside of the cut-off threshold. The Iso value can be set to values from 0.1 to 0.9. Clicking the arrows changes the Iso value in steps of 0.1. To use a different value, enter it from the keyboard. Again, this option can be changed once the interpolant has been created, with the added assistance of a values histogram. Double-click on the indicator RBF interpolant in the Numeric Models folder to open the Edit Indicator RBF Interpolant window and switch to the Cut-off tab.
Once you have created an interpolant, you can adjust its properties by double-clicking on it. You can also double-click on the individual objects that make up the interpolant.
See also:
The Indicator RBF Interpolant in the Project Tree
The new interpolant will be created and added to the Numeric Models folder. The new interpolant contains other objects that represent different parts of the interpolant:
The indicator RBF interpolant expanded in the project tree, showing its boundary, trend, values, isosurface, indicator volumes legend and the Inside and Outside output volumes.
  • The Boundary object defines the limits of the interpolant. See Adjusting the Interpolant Boundary.
  • The Trend object describes the trend applied in the interpolant. See Changing the Trend for an Indicator RBF Interpolant.
  • The sample grouping object () is the inside/outside sample grouping, which is generated by backflagging the indicator calculations on the values used. See Adjusting the Values Used for information on changing settings relating to how the sample points are grouped.
  • The isosurface is set to the specified Iso value.
  • The Indicator Volumes legend defines the colours used to display the volumes.
  • The Output Volumes folder contains the Inside and Outside volumes.
Other objects may appear in the project tree under the interpolant as you make changes to it. See Editing an Indicator RBF Interpolant below for more information on the changes you can make.
Indicator RBF Interpolant Display
Display the interpolant by:
  • Dragging the interpolant into the scene
  • Right-clicking on the interpolant and selecting View Output Volumes
  • Right-clicking on the interpolant and selecting View Isosurfaces
You can also display the sample grouping () generated as part of the interpolant, which is useful in making decisions about the Cut-off value and the Iso value:
The indicator interpolant in the scene, with the red Inside volume displayed together with the sample grouping along the drillholes.
Indicator RBF Interpolant Statistics
You can view the statistics for the indicator RBF interpolant by right-clicking on the interpolant and selecting Statistics. Use the information available to adjust the cut-off value and other interpolant properties:
The Statistics tab for an indicator RBF interpolant, comparing point counts, means and spread for the samples above and below the cut-off value
To edit an indicator RBF interpolant, you can either double-click on the interpolant in the Numeric Models folder or right-click and select Open. The window that appears is divided into tabs that let you change the different objects that make up the interpolant. Many of the options are the same as those for RBF and multi-domained RBF interpolants.
When creating an indicator RBF interpolant, only a basic set of parameters is used. The Edit Indicator RBF Interpolant windows provide finer controls over these basic parameters so you can refine the interpolant to factor in real-world observations and account for limitations in the data.
The Values tab in the Edit Indicator RBF Interpolant window shows the values used in creating the interpolant and provides options for filtering the data. You cannot change the values used, but you can filter the values using the Query filter and Surface filter options.
The sample grouping object () in the project tree is not the values used, but is instead the inside/outside sample grouping generated by backflagging the indicator calculations on the input values (). You can adjust the input values using a contour polyline or by adding points. Both options are available by expanding the interpolant in the project tree, then right-clicking on the sample grouping object ():
The right-click menu on the sample grouping object, offering New Contour Polyline and Add Values.
These options are described below in Adding a Contour Polyline and Adding Points below.
You can adjust the values using contour polylines set to inside (1), outside (0) or to the iso-value. Adding a contour polyline does not affect the indicator’s statistics.
Setting a contour to inside or outside is a useful way of controlling blow-outs. Here, the inside volume occurs in the corner of the model because of the high-value points at the bottom of the drillhole:
A blow-out in the inside volume, where the isosurface balloons out around the high-value point at the bottom of a drillhole.
This can be adjusted by drawing a contour polyline below the bottom of the drillholes and setting it to the outside value. For example, adding a polyline (in green) below the bottom of drillhole shown above removes the blow-out (the part of the mesh with only the edges shown):
The same view after a green contour polyline set to the outside value has been drawn below the drillhole, removing the blow-out.
Polylines must be drawn either on the slicer or on an object. Here a slicer has been drawn across the drillhole and the scene repositioned to draw around the end of the drillhole:
Drawing a contour polyline on the slicer, with the scene rotated so the polyline can be drawn around the end of the drillhole.
Drawing a contour polyline precisely on the drillhole gives Leapfrog Geo conflicting data at the same location, which is why the polyline should be drawn below the drillhole. To draw a polyline below a drillhole without using the slicer, first draw the polyline on the drillhole, then move its nodes so the polyline lies below the drillhole.
Animation showing a contour polyline drawn on a drillhole, then its nodes dragged downwards so the polyline lies below the end of the drillhole.
To add a contour polyline, expand the interpolant in the project tree. Right-click on the values object and select New Contour Polyline:
Selecting New Contour Polyline from the right-click menu on the interpolant's values object.
Next, choose whether you will draw a new polyline or use one already in the project, then select the contour value:
The New Contour window, where you choose between drawing a new polyline or using an existing one and set the value on the contour to 0, 1 or the iso-value.
Click OK. If you have chosen the New Drawing option, the new object will be created in the project tree and drawing tools will appear in the scene. Start drawing in the scene as described in Using the Polyline Editor. When you have finished drawing, click the Save button (). The new contour will automatically be added to the interpolant and will appear in the project tree as part of the interpolant’s values object.
To edit the polyline, right-click on it and select Edit Polyline or add it to the scene and click the Edit button () in the shape list. If you wish to remove a contour polyline from the interpolant, right-click on it in the project tree and select Delete or Remove.
You cannot change the value on the contour once it has been created. You can, however, share the polyline and use it to create a new contour polyline. To do this, right-click on it in the project tree and select Share. The polyline will then be added to the Polylines folder and can be used elsewhere in the project.
Adding Points
To add points to an indicator RBF interpolant, right-click on the values object in the project tree and select Add Values. Leapfrog Geo will display a list of all suitable points objects in the project. Select an object and click OK.
Filtering Values
Query and surface filters can be changed by double-clicking on the interpolant in the project tree, then clicking on the Values tab.
Available filters will be listed in the Query Filter dropdown, building the indicator RBF interpolant from a subset of the available values data.
The Surface filter is enabled by default, with the default selection being the indicator RBF interpolant boundary. You can disable the surface filter to use all the data available, or you can select a different volume from the dropdown list to constrain the data influencing the indicator RBF interpolant. To modify the interpolant’s own boundary, switch to the Boundary tab.
The Values tab of the Edit Indicator RBF Interpolant window, with the query filter and surface filter that constrain the data used.
Compositing Parameters for an Indicator RBF Interpolant
When an indicator RBF interpolant has been created from values that have not been composited, compositing parameters can be changed by double-clicking on the interpolant in the project tree, then clicking on the Compositing tab.
The Compositing tab, where the compositing length, residual end length handling and minimum coverage are set
The Compositing tab will only appear for interpolants created from drilling data that has not been composited.
You can composite in the entire drillhole or only where the data falls inside the interpolant boundary. See Numeric Composites for more information on the effects of the Compositing length, For end lengths less than and Minimum coverage settings.
To change an indicator RBF interpolant’s boundary, double-click on the interpolant in the project tree, then click on the Boundary tab:
The Boundary tab, with the interpolant extents, the Use Topography option and the list of lateral extents applied to the boundary.
Techniques for creating lateral extents for indicator RBF interpolants are the same as those for RBF interpolants. See Modifying an RBF Interpolant’s Boundary With Lateral Extents for more information.
The Cut-Off Value
The Cut-off value is the value you would like to model. If you would like to visualise a shell representing values greater than 2.5, you would enter a value of 2.5 as the Cut-off value. This will be used to determine whether input values are treated as 0 or 1, waste or mineral. Another important consideration in visualising an indicator interpolant surface is the Iso value, which sets the probability you would like to maintain for the indicator interpolant isosurface. See Indicator RBF Interpolant Surfacing and Volume Options for more information.
To change the Cut-off value for an indicator RBF interpolant, double-click on the interpolant in the project tree, then click on the Cut-off tab. The tab also shows the distribution of the data used to create an indicator interpolant:
The Cut-off tab, showing the sample distribution either side of the cut-off value and a histogram with the cut-off marked.
Adjust the Cut-off value, if required, and click OK to process the changes.
You can apply a global trend or a structural trend to an indicator RBF interpolant. To do this, add the interpolant to the scene, then double-click on the interpolant in the project tree. Click on the Trend tab in the Edit Indicator RBF Interpolant window.
See:
Using a Global Trend
The Trend tab with Global Trend selected, and an arrow from the View Plane button to the moving plane and its controls in the scene.
You can also use the Set to list to choose different options Leapfrog Geo has generated based on the data used to build the interpolant. Isotropic is the default option used when the interpolant is created.
  • The maximum value is the relative strength in the direction of the green line on the moving plane.
  • The intermediate value is the relative strength in the direction perpendicular to the green line on the moving plane.
  • The minimum value is the relative strength in the direction orthogonal to the plane.
Using a Structural Trend
You can also set the trend for an indicator RBF interpolant from a structural trend. First, you must create or import the required mesh and create a structural trend.
The Trend tab with the Structural Trend option selected, a trend chosen from the list, and the clustering settings enabled below.
Outside value represents a baseline value, the expected ambient value of the surrounding region. The Outside value is factored into the interpolation algorithm and lowers the interpolated value in the areas away from the known data points. The blending with outside value is very steep. To increase the projection area outside of the area with data the Outside value can be increased to a value just below the cut-off value.
Once you have selected a structural trend, you can adjust the clustering settings. For more detailed information For more detailed information, see the Building a Structural Trend and Clustering Settings and Visualisation topics.
The project tree with an arrow pointing to the Structural Trend object, which now appears in a Clusters folder under the indicator interpolant.
Multiple models can use the same structural trend as an input with different clustering settings, each model stores its own settings.
To adjust interpolation parameters for an indicator RBF interpolant, double-click on the interpolant in the project tree, then click on the Interpolant tab:
The Interpolant tab, with the spheroidal interpolant's sill, nugget, base range and drift settings and the resulting interpolant curve.
To change the properties of the isosurface for an indicator RBF interpolant, double-click on the interpolant in the project tree, then click on the Volumes tab:
The Volumes tab, with the iso value, surface resolution, clipping options and the volume filtering size threshold.
An alternative to double-clicking on the interpolant is to double-click on one of the output volumes, which opens the Edit Indicator RBF Interpolant window with the Volumes tab displayed.
The Iso value can be set to values from 0.1 to 0.9. Clicking the arrows changes the Iso value in steps of 0.1. To use a different value, enter it from the keyboard. The indicator interpolant is a probabilistic numeric model, and the Iso value is the confidence you want to use, the probability that the indicator interpolant shell contains the Cut-off value. A value of 0.1 means there is a 10% confidence, and this will result in a surface that definitely contains the mineralisation, but also will include a lot of waste. Choosing a value of 0.9 means a confidence of 90%, meaning that you almost definitely have just mineralisation inside the isosurface, depicted as a much smaller enclosing volume. However a lot of mineralisation will not be captured and will be treated as being on the ‘outside’, or waste; to achieve a confidence level of 90%, intervals are excluded that are lower probability due to high-grade material being blocked by lower grade material. Mid-range values for Iso value should therefore be preferred in most cases, rather than values at the extreme limits.
Setting a lower value for Resolution will produce more detail, but calculations can take longer. See Surface Resolution in Leapfrog Geo for more information.
Leapfrog Geo uses single pass isosurfacing by default as the accuracy of the mesh is typically adequate with a single pass. Double-pass mesh generation can result in higher accuracy in some situations, but there are tradeoffs. See Single Pass Isosurfacing in the Surface Resolution in Leapfrog Geo topic for more information on this option.
Use Volume filtering to discard smaller parts of the volumes in which you do not wish to carry out further processing. For example, this interpolant has numerous small volumes:
An indicator interpolant's inside volume before volume filtering, with many small isolated volumes scattered around the main body.
Enabling Volume filtering removes the smaller parts:
The same interpolant with volume filtering enabled, so most of the small isolated volumes have been discarded.
