Setting Elevation for Points
You can set the elevation for points objects () by projecting them onto a surface. Any elevation data in the points table will be overwritten by the elevation values from the selected surface.
To set the elevation for points, right-click on it in the project tree and select Set Elevation. The Set Elevation from Surface window will appear:
Unprojected points are points that do not vertically intersect the selected surface. There are two options for handling these points:
  • Leave the elevation field empty.
  • Assign a fixed elevation value.
