Exporting Data Errors
If you need a record of corrected errors, first export the errors. This must be done first, as once errors have been corrected in Leapfrog Geo, they cannot be exported, as they no longer exist.
There are two options for exporting drillhole data errors:
- Export all errors in the drillhole data set.
- Export only the errors from a single table.
To export all errors in the drillhole data, right-click on the Drillholes object and select Export Errors. The Export Drillhole Errors window will appear:
The list shows the files that will be created, one for each table that contains errors. Choose a folder where the files will be saved, then enter a Base file name, which will be added to the front of each file name.
Click Export to export the error files.
To export errors from a single table, right-click on that table and select Export Errors. Choose a location where the file will be saved and click Save.
