Reloading Drillhole Data
Reloading data is necessary when the imported data is modified externally. All drillhole data can be reloaded by right-clicking on the Drillholes object and selecting Reload Drillholes. If you only need to reload a single table, right-click on that table and select Reload Data.
Reloading drillhole data overwrites all existing drillhole data. If you have data you wish to add to the project without overwriting existing data, use the Append Drillholes option.
The process is similar to that for importing drillhole data:
- If the drillhole data was loaded from a file on your computer or a network location, you will be prompted to specify the file locations.
- If the interval table is stored in an ODBC database, you will be prompted to connect to the database. See Selecting the ODBC Data Source.
- If your drillhole data is stored in an acQuire database, you will be prompted to connect to the database. See Connecting to an acQuire Database.
When you reload data, Leapfrog Geo retains the table structure and refreshes the data contained in the tables. This ensures that you do not need to reassign the data type for each column and select the columns to be imported.
