ModFlow Model Export
This feature is only available as part of the Hydrogeology module. See Flow Modelling for more information.
Leapfrog Geo has three options for exporting ModFlow grids:
  • Export the grid as a ModFlow file.
  • Export for Groundwater Vistas. Use this option the first time you export a grid for use in Groundwater Vistas.
  • Export a Groundwater Vistas update. Use this option to generate a set of files that can be imported into Groundwater Vistas as an update.
The Groundwater Vistas options include a zoned layer properties flow (*.lpf) file that includes information about the zones in the grid.
As a ModFlow File
To export a grid as a ModFlow file for use in a package other than Groundwater Vistas, right-click on the grid in the project tree and select Export to ModFlow. You will be prompted to choose a File name and location. Select the options required, then click Save.
For Groundwater Vistas
To export a grid for use in Groundwater Vistas for the first time, right-click on the grid in the project tree and select Export to ModFlow for GWV. You will be prompted to choose a File name and location. Select the options required, then click Save.
If you have previously exported the grid to Groundwater Vistas and have made changes to the grid, use the Export to GWV Updates option.
As a Groundwater Vistas Update
If you have exported a grid to Groundwater Vistas but then make changes to the Leapfrog Geo model, you can export the changes to the model. The set of files containing the changes can then be imported to Groundwater Vistas.
To export a Groundwater Vistas update, right-click on the grid in the project tree and select Export GWV Updates. The Update Groundwater Vistas window will appear listing the files that will be exported. Enter a Base file name to differentiate the original files from the updates. Click Export. The files will be saved in the specified directory.
