Generating a Head Value Mesh
This feature is only available as part of the Hydrogeology module. See Flow Modelling for more information.
Once head values have been imported for a ModFlow model, you can generate a head value mesh. To do this, expand the Simulation Outputs folder. Right-click on the head values object and select Generate Head Value Mesh. The Generate Head Value Mesh window will appear, showing the layers in the model and the timesteps available. Select the layer of the model you wish to generate a head value mesh for, then choose the heads. Click OK to create the mesh, which will be saved to the Meshes folder.
