Clipping a Volume
To clip a closed mesh using another mesh, right-click on the Meshes folder and select Mesh Operations > Clip Volume. The Clip Volume window will appear. Select the meshes you wish to use and whether to retain the inside or outside of the clipped mesh.
Click OK to save the new mesh, which will appear in the Meshes folder. To edit the mesh, double-click on it.
When either of the meshes used to create the clipped volume is modified, the clipped volume will also be updated.
