Grids of Points
You can create a grid of points that can be evaluated against geological and numeric models and exported for use in other modelling packages. This topic describes creating and working with grids of points. It is divided into:
- Creating a Grid of Points
 - Evaluating a Grid of Points
 - Statistics for a Grid of Points
 - Exporting a Grid of Points
You can create a grid of points that can be evaluated against geological models and interpolants and exported for use in other modelling packages.
To create a grid of points, right-click on the Points folder and select New Grid of Points. The New Grid of Points window will appear, together with controls in the scene that will help in setting the grid’s boundary:
If there are objects displayed in the scene, the initial grid dimensions will be based on those objects.
The controls in the scene adjust the size and position of the grid as follows:
- Red and pink handles adjust the Boundary Size.
 - The orange handle adjusts the Base Point.
 - The blue handles adjust the Azimuth.
Set the Spacing and Reference Point, which will control the number of points in the grid. You can set the Reference Point by clicking in the scene. To do this, first click on the Select button (
) for the Reference Point, then click in the scene. The coordinates in the scene will be copied to the New Grid of Points window.
If the number of points will be very large, rendering of the grid in the scene will be disabled.
You will be able to change the settings in this window once the grid has been created.
Click OK to create the grid, which will appear in the Points folder. Double-click on the grid to change its settings.
Once you have created the grid, you will be able to evaluate it against geological models, interpolants and distance functions in the project.
Evaluations will be exported with the grid. See Statistics for a Grid of Points below.
To view statistics on a grid of points, right-click on the grid and select Statistics.
You can export a grid of points in the following formats:
- CSV file (*.csv)
 - GSLIB Data file (*.dat)
 - Surpac Block Model file (*.mdl)
 - Isatis Block Model file (*.asc)
 - Geo 3D Point Data file (*.pl3, *.ara)
For CSV, Surpac Block Model and Isatis format files, all evaluations on the grid of points will be exported as part of the file. For all other file types, only numeric evaluations will be exported.
To export a grid of points, right-click on it in the project tree and select Export. Select the format required, enter a filename and location, then click Save.
