RBF Interpolants
- Creating an RBF Interpolant
- Interpolant Display
- RBF Interpolant Statistics
- Modifying an RBF Interpolant’s Boundary with Lateral Extents
Values Used
- Numeric data contained in imported drillhole data.
Applying a Query Filter
Applying a Surface Filter
The Interpolant Boundary
Once the interpolant has been created, you can further modify its boundary. See Modifying an RBF Interpolant’s Boundary with Lateral Extents and Adjusting the Interpolant Boundary below.
Compositing Options
When numeric values from drillhole data are used to create an interpolant, there are two approaches to compositing that data:
- Composite the drillhole data, then use the composited values to create an interpolant. If you select composited values to create an interpolant, compositing options will be disabled.
- Use drillhole data that hasn’t been composited to create an interpolant, then apply compositing settings to the interpolated values. If you are interpolating values that have not been composited and do not have specific Compositing values in mind, you may wish to leave this option blank as it can be changed once the model has been created.
See Numeric Composites for more information on the effects of the Compositing length, For end lengths less than and Minimum coverage settings.
Set the Surface resolution for the interpolant and whether or not the resolution is adaptive. See Surface Resolution in Leapfrog Geo for more information on the effects of these settings. The resolution can be changed once the interpolant has been created, so setting a value in the New RBF Interpolant window is not vital. A lower value will produce more detail, but calculations will take longer.
See also:
- Copying a Numeric Model
Interpolant Display
Display the interpolant by:
RBF interpolants are created with a basic set of rectangular extents that can then be refined using other data in the project. These extents usually correspond to the ground surface and known boundaries. Creating extents can also be used to restrict modelling to a particular area of interest; for example, modelling can be restricted to a known distance from drillholes by applying a distance function as a lateral extent. Extents do not need to be strictly vertical surfaces and can be model volumes.
Creating Lateral Extents
New extents are automatically applied to the boundary being modified. Leapfrog Geo usually orients a new extent correctly, with red presenting the inside face of the extent and blue representing the outside face. If this is not the case, you can change the orientation by right-clicking on the extent in the project tree and selecting Swap Inside.
Extent from a Polyline
Extents created from polylines can be modified by adding points data, GIS vector data and structural data. You can also add polylines and structural data to the extent. See Adding Data to an Extent, Editing an Extent with a Polyline and Editing an Extent with Structural Data for more information.
Extent from GIS Vector Data
Extents created from GIS data can be modified by adding points data, GIS vector data and structural data. You can also add polylines and structural data to the extent. See Adding Data to an Extent, Editing an Extent with a Polyline and Editing an Extent with Structural Data for more information.
Extent from Points
Extents created from points can be modified by adding points data, GIS vector data and structural data. You can also add polylines and structural data to the extent. See Adding Data to an Extent, Editing an Extent with a Polyline and Editing an Extent with Structural Data for more information.
Extent from Structural Data
Extents created from structural data can be modified by adding points data, GIS vector data and structural data. You can also add polylines and structural data to the extent. See Adding Data to an Extent, Editing an Extent with a Polyline and Editing an Extent with Structural Data for more information.
Extent from a Surface
Extent from Distance to Points
Leapfrog Geo can calculate the distance to set of points and use the resulting distance buffer as a lateral extent for an RBF interpolant. To create a new lateral extent from a distance buffer, right-click on the interpolant’s Boundary object and select New Lateral Extent > From Distance To Points. The Smoothed Distance Buffer window will appear:
You can also use the Set to list to choose different options Leapfrog Geo has generated based on the data used to build the interpolant. Isotropic is the default option used when the interpolant is created.
Extent from a Distance Function
For lateral extents created from from polylines, GIS data, points and structural data, you can change the extent’s settings by double-clicking on it in the project tree.
Surface Resolution
Contact Honouring
Often, surfaces should honour drillhole data and treat data objects such as polylines and GIS data as interpretations. For extents, the Snap to data setting in the Surfacing tab determines whether or not the extent honours the data used to create it. Options are:
- All data. The extent snaps to all data within the Maximum snap distance, which includes drillhole data and any data added to the extent.
- Drilling only. The extent snaps to drillhole data and data objects derived from drillhole data within the Maximum snap distance, but not to other data used to modify the extent. For example, the extent will honour points data derived from drillhole data, but not points data imported into the Points folder.
If you need the extent to honour drillhole data but treat other data objects as interpretations, select Drilling only. To honour some data objects while treating others as interpretations, select Custom, then click on the Inputs tab to enable snapping for individual objects.
Applying a Trend
The Set to list contains a number of different options Leapfrog Geo has generated based on the data used in the project. Isotropic is the default option used when the extent was created. Settings made to other surfaces in the project will also be listed, which makes it easy to apply the same settings to many surfaces.
See Global Trends for more information.
- Structural data. Select from the structural data tables available in the project. If the selected table has query filters defined, you can apply one of these filters by ticking Use query filter and then selecting the required filter from the list. Click OK to add the selected data to the extent. An alternative to adding an existing structural data table to an extent is to edit the extent with structural data. This is described in Editing an Extent with Structural Data below.
You can edit an extent using a polyline, which is described in Editing Surfaces with Polylines. A polyline used to edit an extent will be added to the project tree as part of the extent. To edit the polyline, right-click on it and select Edit Polyline or add it to the scene and click the Edit button (
You can edit an extent using structural data, which is described in Editing Surfaces with Structural Data. A structural data table will be added to the project tree as part of the extent. To edit the table, right-click on it and select Edit In Scene or add it to the scene and click the Edit button (
The Values tab in the Edit Interpolant window shows the values used in creating the interpolant and provides options for filtering the data. Although you cannot change the values used to create an interpolant, you can filter the values using the Query filter and Surface filter options.
Only GIS lines, polylines imported into Leapfrog Geo or polylines created using the straight line drawing tool can be used to create contour lines.
Adding Points
To add points to an RBF interpolant, right-click on the values object in the project tree and select Add Values. Leapfrog Geo will display a list of all suitable points objects in the project. Select an object and click OK.
The Compositing tab will only appear for interpolants created from drillhole data that has not been composited.
You can composite in the entire drillhole or only where the data falls inside the interpolant boundary. See Numeric Composites for more information on the effects of the Compositing length, For end lengths less than and Minimum coverage settings.
See Modifying an RBF Interpolant’s Boundary with Lateral Extents above for information on creating and working with lateral extents.
Lateral extents can be used to restrict modelling to a particular area of interest; for example, modelling can be restricted to a known distance from drillholes by applying a distance function as a lateral extent.
ln(x+s)+c
See:
Using a Global Trend
Using a Structural Trend
You can also set the trend for an RBF interpolant from a structural trend. First, you must create or import the required mesh and create a structural trend. See Structural Trends for more information.
Once a structural trend has been defined for the interpolant, you can edit it by clicking on the trend hyperlink in the project tree, then opening the structural trend applied to the interpolant. The Structural Trend window will appear. See Structural Trends for information on the settings in this screen.
Two models are available, the spheroidal interpolant and the linear interpolant. See The Spheroidal Interpolant Function and The Linear Interpolant Function for more information on the settings in this tab.
If you find that grade shells are overlapping, the resolution may be too coarse. Set Default resolution to a lower value or enable adaptive resolution in the Outputs tab. See Surface Resolution in Leapfrog Geo.
