Importing Screens
This feature is only available with the Hydrogeology extension. See Flow Models for more information.
Screens that have not been imported during the drillhole data import process can be added to the project at any time. To do this, right-click on the Drillholes object in the project tree and select Import From File > Screens or Import From ODBC > Screens.
When importing from a file, Leapfrog Geo will ask you to specify the file location, and then will display the data in the file in the Import Screen window.
When importing from ODBC, you will first be prompted to select the data source. See Selecting the ODBC Data Source.
Columns required are:
- A drillhole identifier
- Start/from and end/to depths
- A value column
Select the required columns and assign the data type for each column. Click Finish to import the file, which will appear under the Drillholes object.
A Leapfrog Geo project can have only one screens table.
