Structural Data
In Leapfrog Geothermal, you can create and edit planar structural data tables directly or from other objects in the project. Structural data can also be used to create and edit many surfaces. Downhole planar structural data and lineations can also be imported, although structural data imported in this way cannot be edited.
This topic describes how to work with structural data in Leapfrog Geothermal. It covers:
- Importing Lineations
- Displaying Structural Data
Leapfrog Geothermal calculates strike using the American right-hand rule; when looking in the strike direction, the plane should dip to the right.
There are two ways to create a new planar structural data table in Leapfrog Geothermal:
- Create a new table as part of creating or editing another object. See Editing Surfaces with Structural Data.
Leapfrog Geothermal supports planar structural measurements in .csv or text formats. This topic describes importing structural data tables that include location information. Downhole structural data can also be imported, as described in Importing Downhole Structural Data.
- Files stored on your computer or a network location. Right-click on the Structural Modelling folder and select Import Planar Structural Data. You will be prompted to select a file.
- From any database that runs an ODBC interface. Right-click on the Structural Modelling folder and select Import Planar Structural Data via ODBC. See Selecting the ODBC Data Source below.
For each of these options, once the data source is selected, the process of importing the data is the same. Leapfrog Geothermal will display the data and you can select which columns to import:
Leapfrog Geothermal expects East (X), North (Y), Elev (Z), Dip and Dip Azimuth columns. The Polarity column is optional. The Base Category column can be used for filtering data once it has been imported.
Once the data has been imported, you can reload and append the data and add columns to the data in a similar manner to well data. See Appending Wells, Reloading Well Data and Importing Columns for more information.
Lineations containing location information can be imported from files stored on your computer or a network location in .csv or text formats. To do this, right-click on the Structural Modelling folder and select Import Lineations. You will be prompted to select a file.
Leapfrog Geothermal expects East (X), North (Y), Elev (Z), Trend and Plunge columns. The Polarity column is optional. The Category column can be used for filtering data once it has been imported.
The categories displayed can also be filtered by other columns in the data table, as described in Filtering Data Using Values and Categories.
Bingham Analysis
Fisher Statistics
There are two ways to initiate structural data selection: from the data object in the project tree/shape list and from a stereonet. The advantage of initiating structural data selection from a stereonet is that the data will be displayed both on the stereonet and in the scene window. This provides the most flexibility for analysing what data belongs to what category. See Selecting Data in the Stereonet and Using the Scene Window with the Stereonet for more information.
- Edit the data in the table directly by double-clicking on the structural data table in the project tree. See Working with Data Tables.
Unprojected points are data points that do not vertically intersect the selected surface. There are two options for handling these points:
- Leave the elevation field empty.
- Assign a fixed elevation value.
