Setting Elevation for GIS Objects and Images
You can set the elevation for GIS objects and images by:
- Using a fixed elevation
- Using the elevation data from one of the object’s attributes
- Using the elevation data from a surface in the project
The options available depend upon the type of object.
Fixed Elevation | From Attribute | From Surface | |
GIS lines | X | X | X |
GIS points | X | X | X |
2D grids | X | - | X |
GIS lines drawn in Leapfrog Geothermal | X | - | - |
GIS lines extracted from polylines | X | - | X |
Images | X | - | - |
To set the elevation for a GIS object or an image, right-click on it in the project tree and select Set Elevation. The Set Elevation window will appear, displaying the available options. Select the option required and click OK.
