Batch Apply QC
Use the Batch Apply QC option (geogxnet.dll(Geosoft.GX.AirborneQC.BatchQC;Run)*), from the Airborne QC > QC menu, to apply airborne quality control in batch mode.
Batch Apply QC dialog options
Altitude deviation |
Select the Altitude deviation check box to enable the Altitude deviation tab below. Click here for technical help for the Altitude Deviation parameters. |
Line separation |
Select the Line separation check box to enable the Line separation tab below. Click here for technical help for the Line Separation parameters. |
Sample separation |
Select the Sample separation check box to enable the Sample separation tab below. Click here for technical help for the Sample Separation parameters. |
Velocity deviation |
Select the Velocity deviation check box to enable the Velocity deviation tab below. Click here for technical help for the Velocity Deviation parameters. |
Flight deviation |
Select the Flight deviation check box to enable the Flight deviation tab below. Click here for technical help for the Flight Deviation parameters. |
Flight/tie differences |
Select the Flight/tie differences check box to enable the Flight/tie differences tab below. Click here for technical help for the Flight/tie Differences parameters. |
Sensor noise |
Select the Sensor noise check box to enable the Sensor noise tab below. Click here for technical help for the Sensor Noise parameters. |
Diurnal variations |
Select the Diurnal variations check box to enable the Diurnal variations tab below. Click here for technical help for the Diurnal Variations parameters. |
Output map |
Select the Output map check box to enable the Map name parameter below. |
Map name |
Specify the name of your output map. This is a required field when the Output map field above, is selected. |
You can select any number of quality control processes to apply to your airborne data. Each tab provides specific parameters for each of the quality control processes.
