New Project from acQuire
Use the DH-Data > New Project > New Project from acQuire menu option (ACQHOLE GX) to import drillhole information from acQuire database through ODBC connection.
Drillhole - New Project from acQuire dialog options
Project Name |
Name of the project to import. Script Parameter: ACQIMPORT.PROJECT |
Project directory |
The directory in which to create the new drillhole project. (read only) Script Parameter: DH.PROJECT_DIR |
Load Parameter Setting |
Parameter setting file. Script Parameter: ACQIMPORT. PARFILE |
Auto-convert negative assays? |
If "yes", all values in data recognized as "Assay" type are scanned on import, and those values less than zero are replaced by positive values one-half the size (e.g. values are multiplied by –0.5). This operation is made under the assumption a negative values is actually the negative detection limit of the assay in question. For statistical reasons, these values are replaced with one-half the detection limit. By default, negative assay values are not auto-converted. Script Parameter: ACQIMPORT. CONVERT_NEGATIVES |
Directory |
Specify the directory in which to create the new drillhole project. |
Drillhole information is imported into four GDB files, which are in compatible format for the Drillhole, XXXX_Collar.gdb, XXXX_assays.gdb, XXXX_geology.gdb and XXXX_survey.gdb where XXXX is the project name given in the dialog.
Refer to the acQuire’s documents about data selection and query using the "Select data from acQuire" dialog.
