Import ZLS Data
Use the Moving Platform Gravity > Import > Import ZLS Data menu option (AGIMPGRAV GX) to import a gravity data file into a new database.
Import ZLS file(s) dialog options
ZLS file(s) |
Name of the gravity data file(s) (ASCII file) to import. If multiple files are selected (files should be separated by |), they should all reside in the same directory. Script Parameter AGIMPGRAV.FILE |
Name of the import template. The default is ZLSgrav2.i3. Should it be necessary, you could customize this file and save it to your local working folder. Script Parameter AGIMPGRAV.TEMPLATE |
Survey date |
Gravity survey date string in format YYYY/MM/DD. Script Parameter AGIMPGRAV.DATE |
This GX will use the ZLSgrav2.i3 template file to import the survey gravity data file(s) into a new database. The database acquires its base name from the first import data file.
This GX also concatenates the Hour, Min and Sec channels into the Time channel in hour units.
