Merge GPS Data to Survey Database
Use the Moving Platform Gravity > Import > Merge GPS Data to Survey Database menu option (AGMERGE GX) to merge GPS data into the gravity database.
Merge GPS Data into Gravity Database dialog options
Gravity database |
Name of the gravity database. Script Parameter AGMERGE.GRAV |
GPS database |
Name of the GPS database. Script Parameter AGMERGE.GPS |
Merge GPS data (Latitude, Longitude and Height channels) into gravity database by matching the Date and Time values from the Date and Time channels.
The GX first creates the "_lookup.tbl" file from the GPS database with Date, Time, Latitude, Longitude and Height fields in the table. Then merges Latitude, Longitude and Height data into the gravity database by using Tablelook2_DU method with Date and Time indexes.
