Recalculate Gravity from Raw ZLS Data
Use the Moving Platform Gravity > Import > Recalculate Gravity from Raw Data menu option (AGRECALC GX) to recalculate gravity from raw data.
Recalculate Gravity from Raw Data dialog options
Spring tension channel |
The Spring tension channel name. The default name is "SprTens". Script Parameter AGRECALC.SPRTENS |
Raw beam channel |
The Raw beam channel name. The default name is "RawBeam". Script Parameter AGRECALC.BEAM |
Cross coupling channel |
The Cross coupling channel name. The default name is "CrossCoupl". Script Parameter AGRECALC.CRSCPL |
Calibration factor
Calibration factor (Fcal). The default is 0.9966. Script Parameter AGRECALC.FCAL |
K factor of beam (? mv/minute=1mGal) |
K factor of beam (? mv/minute=1mGal) (K) The default is 2 mv/minute=1mGal. Script Parameter AGRECALC.K |
Output recalculated gravity channel |
The Output recalculated gravity channel name. The default name is "RecGravity". Script Parameter AGRECALC.OUTCH |
The spring tension channel (SprTens) will be recalculated by dummy the repeat values and linearly interpolating these dummy values, and then stored into the new SprTensRec channel.
The re-calculation formula is:
RecGravity = (SprTensRec + CrossCoupl)*Fcal + (RawBeamDerivative*60/K)
