Pick Anomalies
Use the Database Tools > Channel Tools > Pick Anomalies menu option (ANOMPICK GX) to pick anomalies from one channel or a selection of channels.
Pick Anomalies dialog options
Channels to pick anomaly |
Name(s) of input channel(s). Comma delimited names are accepted Script Parameter: ANOMPICK.INCHAN |
Format of result |
Format of results to save: Values (default), Numeric or Alphabetic Script Parameter: ANOMPICK.RESULT |
Base level |
Base level Script Parameter: ANOMPICK.LEVEL |
Minimum amplitude |
Minimum amplitude of the filtered data in an input channel defines a minimum value which can be considered as anomaly Script Parameter: ANOMPICK.AMPL |
Pick anomalies in a channel
For a point of the channel to be picked as an anomaly, it must be a peak (local maximum) value which is greater than the ‘Base level’. The difference between this peak value and values of the adjacent troughs (local minima) must be greater than the ‘Minimum amplitude’.
Channel to store results
The picked anomalies can then be saved in the respective output channels. They can be either alphabetical or numerical numbers or actual values of the input channels.
