Free-Air Correction
Use the Moving Platform Gravity > Corrections by Steps > Free-Air Correction menu option, (geogxnet.dll(Geosoft.GX.Gravity.FreeAirCorrection;Run)*), to calculate the free-air correction.
Free Air Correction dialog options
Free air equation
Choose the equation to apply. See the Application Notes below.
Script Parameter AGFACOR.FREEAIR [0- Ellipsoid , 1- Telford]
Height channel
The elevation of the observation platform. For airborne surveys, this is the height above the sea level. The default will be set to "Height", if a channel by this name exists in the current database.
Script Parameter AGFACOR.HEIGHT
Latitude channel
The latitude channel name. The default name is "Latitude".
Script Parameter AGFACOR.LATITUDE
Output free-air correction channel
The free-air correction channel name. The default name is "FaCor".
Script Parameter AGFACOR.OUTCH
Application Notes:
The correction formula:
The Ellipsoid correction formula:
