Clear Mask Channel
Use the Clear Mask Channel option (CHCLEARMASK GX) to set all values in the Mask channel to 1.
Clear Mask Channel dialog options
Mask channel |
Select a mask channel from the drop-down list. Channels selected for the drop-down list either have their CLASS attribute set to "MASK", or include the string "mask" in the channel name (case-insensitive). The default mask channel is set from the CHPREFERENCES GX (Geochem Import|Preferences). If the channel does not exist, it will be created as a mask channel. Script Parameter: CHCLEARMASK.MASK |
