Classify by Map Group
Use the Geochem Analysis > Classify by Map Group option (CHGRPPLY GX) to create or update a mask channel from a group inside a map.
Create Mask Channel from a Map Group dialog options
Group to mask |
Select the map group to mask. Script Parameter: CHGRPPLY.GROUP |
Mask channel |
Select the Mask Channel Name. The default mask channel is set from the CHPREFERENCES GX (Geochem Import/Preferences...). Script Parameter: CHGRPPLY.MASK |
Work inside or outside area |
Select to work "Inside" or "Outside" the mask polygon. Script Parameter: CHGRPPLY.WORK |
Append/New |
Select to append to a Mask channel or create new Mask channel. "Append" means that values that are already selected ("1") in the Mask channel will remain selected – these will not be reset to "dummy" even if the data is not found to be included in the current masking operation. "New" means that every value in the mask channel will be updated based on the current mask operation. Script Parameter: CHGRPPLY.APPEND |
Only rectangles and polygons are included.
