Import Assay Data
Use the Geochem Import > Import Assays menu option (CHIMPLAB GX) to import a single lab assay batch to a database. The data must currently be contained in an ASCII tabular file, in a supported database, or the clipboard.
Import Assay Data dialog options
The assay batch name is assumed to be the same as the root file name. This import creates a mask channel and sets the values to "1". The name of the mask channel is taken first from the Geochemistry preferences, and if that value is not defined, then defaults to "ChemMask".
