Import Survey Data
Use the Geochem Import > Import Survey Data menu option (CHIMPORT GX) to import geochemical field survey data to a Geosoft database. Field survey information may be contained in a tabular ASCII file (including Excel CSV format files), an external database table, or the clipboard
Import Survey Data dialog options
A field survey data set is a list of all samples in a planned geochemical survey project together with sample locations, data standards and sample duplicates. The data may also include geology, comments, field codes, or whatever other field survey information is related to the samples. A field survey data set does not include geochemical assays.
The field survey file must contain a "Sample" column together with any survey information that is related to the sample. Typically, the following information is contained in the survey file:
Sample |
The sample name, which is a string of up to 16 characters. Every sample must have a unique sample name. |
X |
x location in local grid |
Y |
y location in the local grid |
Duplicate |
If the sample is a duplicate, this is a number that indicates the order of duplicate samples. Duplicates are assumed to be in pairs based on the duplicate order – 1,2 are duplicates, 3,4 are duplicates, etc. This allows duplicates to be distributed randomly within the batch if required. |
Standard |
If the sample is a standard, this is the standard name. We assume there will be a standards table that contains historic standard results. |
Database channels will be created for these fields even if the field data source does not include this information. Any other information may also be imported. Common example of other information are geology description, sample codes and comments.
