Line Location Plot
Use the Geochem Map > Line Plots > Line Path menu option (CHLINE GX) to plot and label survey lines.
Line Location Plot dialog options
Line thickness (in mm) |
line colour Script Parameter: FLIGHT.LINE_COLOR |
Line colour |
line thickness in mm. Script Parameter: FLIGHT.LINE_THICKNESS |
Label format |
label format Script Parameter: FLIGHT.LABEL_FORMAT |
Label location |
label location Script Parameter: FLIGHT.LABEL_LOCATION |
Label size |
label size in mm. Script Parameter: FLIGHT.LABEL_SIZE |
Label colour |
label colour Script Parameter: FLIGHT.LABEL_COLOR |
Label weight |
label weight (normal, thick, thin) Script Parameter: FLIGHT.LABEL_WEIGHT |
Horizontal offset |
horizontal label offset in mm. Script Parameter: FLIGHT.H_OFFSET |
Vertical offset |
vertical label offset in mm Script Parameter: FLIGHT.V_OFFSET |
This GX is for use with geochemical data acquired along survey lines. The following information provides additional information about specifying values.
This is a string that describes the label format. Each character of the string represents a component of a full line label. For example, a full line label might be:
number "1023" use character "N"
version "4" use character "V"
flight "13" use character "F"
To plot a full label, specify "LNVF".
LABEL_LOCATION
NONE - do not plot a line label
END - plot centered off the ends of the line
ABOVE - plot above the ends of the lines
BELOW - plot below the ends of the line
LABEL_LOCATION
NORMAL
ULTRALIGHT
LIGHT
MEDIUM
BOLD
XBOLD
XXBOLD
V_OFFSET
H_OFFSET
Vertical and horizontal label offset in mm. The interpretation of the offsets depends on the LABEL_LOCATION:
END
L100.2 -------------------------- L100.2
H_OFFSET controls distance from label to line.
V_OFFSET controls verical offset from center.
ABOVE
L100.2 L100.2
H_OFFSET controls label distance above the line.
V_OFFSET controls offset in from line end.
BELOW
L100.2 L100.2
H_OFFSET controls label distance below the line.
